Skynet Is default firewall good enough?
Do you add this in 5 > 1 in Skynet?
No... actually you need to switch to a different filter list in order to use this... under 3 -> 2
And then insert this URL:
https://raw.githubusercontent.com/ViktorJp/Skynet/main/filter.list
(or one of your own choosing/making)
Great, done, thanks!
You, sir, are a mad, scripting genius! :p
Viktor, how do I create my own list, just thought I'd ask so I can figure it out myself in the future. thanks.
Create github acc, copy his list and add yours in :p
@Skeptical.me this is correct. Just create a list of urls pointing to similar plaintext IP4 blacklists, and make it publicly available so you can point to it with a URL within skynet, then you're all set! (Poet?) Feel free to use mine or @SomeWhereOverTheRainBow's as examples! ;)
Since I was also interested in using a personal list, but not having an account on github, I studied the script code a bit and did a little trick to read a file directly on the router.
first I created the filter.list file in the following path:
/jffs/configs/filter.list
copied inside as an example the following URLS
https://raw.githubusercontent.com/stamparm/ipsum/master/levels/3.txt
https://raw.githubusercontent.com/stamparm/ipsum/master/levels/4.txt
https://raw.githubusercontent.com/stamparm/ipsum/master/levels/5.txt
https://raw.githubusercontent.com/stamparm/ipsum/master/levels/6.txt
https://raw.githubusercontent.com/stamparm/ipsum/master/levels/7.txt
https://iplists.firehol.org/files/alienvault_reputation.ipset
https://iplists.firehol.org/files/bds_atif.ipset
https://iplists.firehol.org/files/cybercrime.ipset
https://iplists.firehol.org/files/dyndns_ponmocup.ipset
https://iplists.firehol.org/files/et_block.netset
https://iplists.firehol.org/files/et_compromised.ipset
https://iplists.firehol.org/files/firehol_level2.netset
https://iplists.firehol.org/files/firehol_level3.netset
https://iplists.firehol.org/files/spamhaus_edrop.netset
https://iplists.firehol.org/files/urlvir.ipset
then I modified the skynet.cfg configuration file in the skynet installation path and modified the configuration entry as follows:
customlisturl="file:///jffs/configs/filter.list"
and via the firewall script menu launched the update (3 > 1) and everything worked properly.
I don't know if it can be useful but I wanted to share my experience
Greetings
Commodoro
Greetings
Commodoro
Awesome! I was wondering if it was possible to do that, instead of it needing a publicly available URL. Really great to know this! Thanks much @commodoro!!
Greetings
Commodoro
Thank you for sharing! Will give this a try later. I only created github because of the list lol
For the blocking lists, this discussion has been to use Skynet to do the blocking. But what if you added a blocking list to Diversion, say firehol_level1? Is it equally as effective as adding it to Skynet?
