Hi All,
I have an unusual use case in that the guest network (seperate SSID) I've enabled on my RT AC88U which sits at the front of my house is shared with my next door neighbour who happens to be family. He connects to my guest wifi in his house using an Asus RP-AC52 which is a wireless repeater and all works well.
The guest network is not able to access the intranet (my stuff), so everything is well isolated.
The problem with this arrangement is the main wifi on the router doesn't quite cover the back rooms in my house or the garden, so I thought I had a cunning plan to fix this.
I purchased a Ubiquiti UAP‑AC‑PRO wifi AP and stuck that on the landing ceiling upstairs and plugged that into the existing network. That works brilliant 5G everywhere and only drops down to 2G in the garden, lots of wifi goodness.
To finish up I wanted to turn off the old main wifi on the asus router and just leave the guest network running. However there is no option for me to do that, if I disable the 2g radio, it disables the 2g guest network too, same problem with the 5g network too.
So my next thought is to turn off the guest wifi and make the main wifi the guest wifi, and this is where I need your help.
How do I force the main router wifi to perform in the same manner as the guest wifi, only has access to the internet and not my stuff?
Hope that all makes sense and you can offer me some help.
I am currently running Merlin Firmware Version:384.5
Thanks!
Thanks!
