Is there a lot of problems after upgrading to 384.4 firmware?
menaceinc
I didn't have too much problems other than trying to figure out the default ip address (192.168.50.1) after factory reset. Then I re-installed scripts like AB-Solution...etc. It was like setting up a new router all over again.
...figure out the default ip address (192.168.50.1) after factory reset
No problems at all in my case - both routers (see below) worked like a charm on the first try (coming from 380.69 without factory reset). :cool:
But there are multiple postings/threads where people have issues with wireless (not sure if they did a factory reset) and other phenomenon - but again not clear what they have done or not to get there. :confused:
Really strange router IP address after reset: The default should be 192.168.1.1 - not .50.1 at the end... :eek:
Yes, I was really struggling to find out the ip address. I knew it was something other than 192.168.1.1, I have since written it somewhere for next time (hope it won't be next time)
I will try your method with factory reset next time, thanks!
