I am trying to use my 8800L hotspot as a usb modem to my AX86S. I am using the latest version of merlinwrt but I keep getting disconnects from the hotspot on the router
y 5 05:56:23 kernel: +++++ BRCM skipping port_feat_c_connection for warm reset
May 5 05:56:23 kernel: usb 2-2: USB disconnect, device number 2
May 5 05:56:23 kernel: usb 2-2: new SuperSpeed USB device number 3 using xhci-hcd
May 5 05:56:23 kernel: cdc_ether 2-2:1.0 eth7: register 'cdc_ether' at usb-xhci-hcd.0-2, CDC Ethernet Device, 00:15:ff:92:72:29
May 5 05:56:23 hotplug: add net eth7.
May 5 05:56:33 kernel: +++++ BRCM skipping port_feat_c_connection for warm reset
May 5 05:56:33 kernel: usb 2-2: USB disconnect, device number 3
May 5 05:56:33 kernel: cdc_ether 2-2:1.0 eth7: unregister 'cdc_ether' usb-xhci-hcd.0-2, CDC Ethernet Device
May 5 05:56:33 hotplug: remove net eth7.
May 5 05:56:33 kernel: usb 2-2: new SuperSpeed USB device number 4 using xhci-hcd
May 5 05:58:10 kernel: usb 3-1: USB disconnect, device number 2
May 5 05:58:11 kernel: usb 3-1: new high-speed USB device number 3 using ehci-platform
May 5 05:58:11 kernel: cdc_ether 3-1:1.0 eth7: register 'cdc_ether' at usb-ehci-platform.0-1, CDC Ethernet Device, 00:15:ff:92:72:29
May 5 05:58:11 hotplug: add net eth7.
May 5 05:58:21 kernel: usb 3-1: USB disconnect, device number 3
May 5 05:58:21 kernel: cdc_ether 3-1:1.0 eth7: unregister 'cdc_ether' usb-ehci-platform.0-1, CDC Ethernet Device
May 5 05:58:21 hotplug: remove net eth7.
Tried both the USB 3.0 and 2.0 ports. Any idea?
EDIT:
I got around this by using a USB C hub that has ethernet on it. For some reason if I power the hub with the usb C passthrough power port it makes the 8800L act up, but if i just let the MiFi drain its own internal battery it seems to work.
EDIT:
