Issues running OSCAM 11877 on Asus router with AsusWRT Merlin
userned
Hi everyone,
I’m having an issue running OSCAM 11877 on my Asus RT-AC86U router with AsusWRT Merlin. I’m trying to get it running, but I’m facing problems with dependencies and libraries.
Here are the details:
  1. Environment:
    • Router: Asus RT-AC86U
    • System: AsusWRT Merlin
    • Architecture: aarch64
    • GLIBC version: 2.27
  2. Installed packages and libraries:
    • I installed Entware to have access to the necessary libraries.
    • The libraries libssl (version 1.1) and libcrypto (version 3) are installed.
  3. OSCAM file:
    • I’m trying to run OSCAM version oscam-Blue_Shadow-git11877-802@cd33226c-aarch64_generic-webif-dvbapi-ssl-libdvbcsa-emu-ipv6-icam-signed.tar.gz.
4. Error:
After extracting the OSCAM file and running it, I get an error related to the GLIBC version and missing symbols in the library files. An example error message:
/opt/bin/oscam: relocation error: /tmp/mnt/USB/entware/lib/libc.so.6: symbol _dl_exception_create, version GLIBC_PRIVATE not defined in file ld-linux-aarch64.so.1 with link time reference
I’ve tried the following solutions, but none of them worked:
  • Installing libraries in different versions (libssl, libcrypto).
  • Using symbolic links to point to the correct versions of the libraries.
Does anyone know if there is a compiled version of OSCAM with a web interface (webif) that will work on my router? I would appreciate any help or suggestions!
Thanks!
