Hi Kamoj,I really don't know how fast these hw-issues deteriorate. I'm just happy to find a way to extract the info.
I'm no HW expert - either.
All found errors have been corrected, but maybe you should keep an eye on it and see if it gets worn bad - because that's not good.
my 7800 is time to time restarting with version 5.3 b17. not sure if it is related to high temperature
I have Uninstalled. 17 and installed. 18. Router looks physically fine. I'll let you know. TnxLook in Router Information for temperatures!
If critical anything can be broken, so take care your router!
Also if using OpenVPN e.g. switch off Turbo mode.
No issue with 18 indeed. 17th was giving me temperature problemsInstalled 18 temperature low ( the eggs are soft ) openvpn stable working. Thanks kamoj very good job !
Wysłane z mojego SM-G965F przy użyciu Tapatalka
Hi, all. I'm trying to configure DNSCrypt to use our Cloudflare Gateway credentials. Simply, I just have to change the server to:
https://xxxxxxxxxx.cloudflare-gateway.com/dns-query (gateway ID redacted)
If I press "Get Current" under servers, I can see the current Cloudflare ones I've previously used. If I select and delete those, it says to type or paste my own servers here. When I do that and hit "save" it doesn't save it and just reverts to the plain old Cloudflare I previously had.
Any ideas how to implement this?
Dnscrypt2 removes not valid servers.
You shall only write the short one word name of the server.
PS
You can manually edit /etc/dnscrypt-proxy-2.toml
but that will not help if you declare invalid servers.
The invalid servers will still be in the configuration.
So what is the best way to input that server so that DNSCrypt will use it? If I modify the file, you're saying it would consider it an invalid server...
Thread starter | Title | Forum | Replies | Date |
M | Kamoj Kamoj Addon 5.5 Beta for Netgear R7800/R8900/R9000 with Voxel FW - Continuation | NETGEAR AC Routers and Adapters (Wi-Fi 5) | 8 |
Welcome To SNBForums
