Downloaded 5.3b21 again in case it got corrupted first time, reinstalled and running ok nowAfter loading latest version 5.3b21 lost internet.Also after uninstalling @kamoj addon still no internet,had to reinstall Voxel latest and gone back to 5.3b20
@kamoj dnscrypt problem solved with this update props to ya.
ssh key installed without a problem copied my ppk file for use with all my devices and was fine after add-on update excellent work
On a side note, you have been pumping out updates frequently and by no means am i complaining.
I would like to request and add-on update automation addition to your add-on
I would think a static name and a constant location to retrieve the file from would aid in this matter
uninstall, reboot, re-install, reboot a retrieval of the file could be done by the user and placed in a designated location or an outright download from a host.
Just a thought, I'm not a programmer and this might be unnecessary or open it up to a myriad of problems but it really would be cool hehe
yeah im lazy there i said it
Changes in kamoj-addon beta version 5.3b22
- Enhanced: Supervision of Internet, OpenVPN, Wireguard, DNSCrypt2, Stubby, AdGuard, dnsmasq, net-lan
Now back to original idea of 5.3b17, but with several improvements and logging.
Still not full coverage since router itself use dnsmasq and no tunneling
@kamoj ummmm not sure if its something I did or maybe a bug. My flash drive is improperly displayed but the df output is correct.
still running 21b but I noticed it be4 also
Filesystem 1k-blocks Used Available Use% Mounted on
tmpfs 512 0 512 0% /dev
ubi0verlay_volume 51032 7288 41100 15% /overlay
overlayfs:/overlay 51032 7288 41100 15% /
/dev/sdb 3900568 538696 3163728 15% /tmp/mnt/sdb
/dev/sda1 976759804 461882800 514877004 47% /tmp/mnt/sda1
tmpfs 512 0 512 0% /hipplay/dev
/dev/sda1 976759804 461882800 514877004 47% /hipplay/home/0external/C2667E95667E89C5
/dev/sdb 3900568 538696 3163728 15% /hipplay/home/0external/78c7314e-cdf3-47ae-b761-eb8bd4c7ca40
tmpfs 241760 0 241760 0% /hipplay/dev/shm
@kamoj Would it be possible to add express opvn to the addon.
Q: Why don't you directly support ExpressVPN?
A: Because they have no free trial, and no add-on user has wanted to let me
use their credentials even for a day, or payed me for a trial period.
I can not add OpenVPN providers without being able to test it!
9). Read Release Notes with changes: release_notes.txt
10). Read Frequently Asked Questions: FAQ.txt
Fair comment.From Kamojs FAQ:
General to all beta testers including myself is to remember that as beta testers we also have some responsibility to help as good as our abilities let us. We get a very nice product but we have to keep remind ourself that we are a part of a program to get this stuff early and that we signed up to help test and improve the work. Kamoj is for sure doing allot of work to try prevent some problems that can be user related by doing allot of documentation. To be responsible and to show our motivation to help I think it's important to spend time with the beta, not just enjoy it but see it as project we signed up to and should be a part in.
Kamoj dont seem to ask to much but from his read me file:
Let us all beta testers remember that we signed up to be a part of a great project.
fr='USB_DEVID="$(find /dev -type b -name "$USB_DEV""*" | grep -v "$USB_DEV$" | head -n1)"'
to='USB_DEVID="$(df | awk "/^\/dev\/$USB_DEV/ && /\/tmp\/mnt\/sd/ {print "'$1'"}" | head -n1 | xargs)"'
sed -i "s#$fr#$to#g" /usr/bin/addon_info_update.sh
kamoj,
thanks for the help with configuring the *.ovpn file for PureVPN. Lately their service has been a bit rough but as of 5.3b22 of your addon the killswitch & reconnect is working. Here are 3 log files that may provide some useful information.
The Port 53 fail from yesterday morning was just after I updated to 5.3b22 and everything seemed a bit touchy and I spent a fair bit of time warm and cold rebooting the router and rebooted the modem too. However, the other Port 53 file presents results from yesterday afternoon, evening and night. It started OK and, despite disconnects from the provider, your reconnect scheme kept it going. Early this morning I changed the *,opvn file to use port 1194 and it has been fine since then with this more standard VPN port, although dropouts/reconnects are evident.
Overall, 5.3b22 is a wonderful improvement in features and stabilty with my rather volitle VPN service. I'l keep exploring and reporting as I try to better understand VPN and the capabilities of this router with Voxel's firmware and your essential addon.
LSM
I have a patch for the USB info problem, can you try it and report back?
(Others can try too - of course!)
Code:fr='USB_DEVID="$(find /dev -type b -name "$USB_DEV""*" | grep -v "$USB_DEV$" | head -n1)"' to='USB_DEVID="$(df | awk "/^\/dev\/$USB_DEV/ && /\/tmp\/mnt\/sd/ {print "'$1'"}" | head -n1 | xargs)"' sed -i "s#$fr#$to#g" /usr/bin/addon_info_update.sh
grep -Hv "^ATA\ *$" /sys/block/*/device/vendor | sed s/device.vendor:.*$/device\\/uevent/ | xargs grep -H ^DRIVER=sd | sed s/device.uevent.*$/size/ | xargs grep -Hv ^0$ | cut -d / -f 4 | xargs
Same thing i unmounted it also upon mount it shows up same way. tossed in a reboot with the drive removed and still same thing
Problem has changed a little both drives are represented as /sda1
df is reporting it correctly
Thread starter | Title | Forum | Replies | Date |
M | Kamoj Kamoj Addon 5.5 Beta for Netgear R7800/R8900/R9000 with Voxel FW - Continuation | NETGEAR AC Routers and Adapters (Wi-Fi 5) | 8 |
Welcome To SNBForums
