Hi can you om me to the latent beta Adobe please
Best Regards Hannez
Skickat från min iPhone med Tapatalk
New beta available!
Changes in kamoj-addon beta version v5.1b9-2:
- Router Information: Added: Flash memory chip type and UBI erase counters.
- Kamoj Menu + Hidden Menu: Added color change of selected Menu item. All work by nsx
- Settings: Corrected js error for non-implemented function.
Bug found by nsx.
- OpenVPN Bypass: Bugs concerning devices with reserved addresses corrected.
Bug found by nsx.
(Please test it if you can. I need more feedback on this function.
Also it is not done/tested for users of ipv6)
Installed and working with no problems on R7800. I use VPN bypass for 2 attached devices, 1 via wifi and the other via ethernet. Both are working OK.New beta available!
Bug found by nsx.
Bug found by nsx.
If Guest Network is enabled, Router Info displays no RSSI for connected devices (says no device connected), whether on Guest network or the main normal one. Disabling Guest network brings back the connected devices with their RSSI
They are visible in NG's log page, though
Thread starter | Title | Forum | Replies | Date |
M | Kamoj Kamoj Addon 5.5 Beta for Netgear R7800/R8900/R9000 with Voxel FW - Continuation | NETGEAR AC Routers and Adapters (Wi-Fi 5) | 34 |
Welcome To SNBForums
