Check box issue not fixed; Show button issue not fixed.New beta available!
Changes in kamoj-addon beta version 5.2b2-4
- Router Information: Removed dnscrypt1 support
- Settings: Output timestamp in the dmesg log: Removed
(Now always set at early boot)
- Settings: HDD Spin Down: Activate after re-install
- Settings: Router Information renamed to Router Internals
- DNS Privacy and Ad-Blocking: None/Stubby/DNSCrypt Proxy 2 radio buttons (Thx: @wurstbrot)
Fixed problem for some users with non-working radio buttons (@jrbmw a.o.)
- Settings: Set some functions on / off: (Thx: @wurstbrot)
Fixed problem for some users with non-working check-boxes (@Droidrat a.o.)
- Settings: Router Internals: Show boxes don't work (html-code displayed instead) (@Droidrat a.o.)
Fix implemented, but can not test it myself.
However, the first time I tried to check Output WiFi devices info to syslog when loading Router Information page, the checked box persisted slightly longer before the check mark disappeared. When I tried a second time, the timing appeared to be the same as the prior build.
Thank you for your feedback!
Can you make the debug thing again, to make sure the request stays in the browser?
Also just installed the beta v5.2b2-4
Then I also enabled the OpenVPN Client. -> perhaps I didn't read the instructions good enough, but I didn't see much on the how to get the ovpn files onto the router. Expected that I could put them on my USB stick, and that it would read them from there. But that didn't work so I used ssh to copy them to /etc/openvpn/config/client
Next I viewed the Router information and noticed these messages:
OpenVPN Clients Available (1) ipvanish-NL-Amsterdam.ovpn
OpenVPN Client Name xxxx.ipvanish.com xxx.xx.xx.xxx:443
OpenVPN Client Status ERROR - Too many clients started (3) tun21: xxx.xx.xx.xxx
Wireguard Client Name : : endpoint:
Wireguard Client Status ERROR wg0: No wg0 xxx.xx.xx.xxx
DNSCrypt Proxy v2 DNSCrypt v2 is not running, but is enabled.
The Wireguard error disappeared when I disabled Wireguard. -> perhaps for a future version, keep Wireguard disabled by default / or disabled as long as it is not yet configured?
(This might also apply to the OpenVPN Client -> I think this was also enabled by default)
The DNSCrypt Proxy v2 error: I think I also already saw that one on v5.0 beta -> this message is wrong, because I don't have DNSCrypt V2 (or Stubby) enabled. Radiobutton on the DNS Privacy page is set to none
And I also don't have an explanation for the OpenVPN Client status (error too many clients started (3))
Changes in kamoj-addon beta version 5.2b2-5
- Settings: Router Internals: Changed code to avoid many "[Warning] skb_warn_bad_offload!!!"
@kamoj, I installed 5.2b2-5, and it doesn't fix any of the "button, check box, 'Show'" issues that I have reported.
I saw that you advised someone that ONE user had reported this (presumably referring to me). That is incorrect. There are at least 2 reports, I believe. See also https://www.snbforums.com/threads/kamoj-add-on-5-1-beta-testing-poll.62315/page-7#post-577470
I can add one thing to my previous reports. At the bottom of the Router Information page, there is a check box for Auto Refresh. If I check the box, and press "ok", the page will indeed refresh after 10 seconds. However, once it refreshes, the box will display as unchecked, and the page will therefore not automatically refresh a second time. I'm not sure that this is the desired behavior.
Let me know how I can help to get all of this resolved.
Thanks for latest release Kamoj .All my radio buttons still working ok.One thing I have noticed is
When using wireguard the internet led stays orange although connected to internet and running ok.
Thank you for your response. I have attached a file which shows the output I receive when I press the "Show" button for Flash Info. This is the same as the output of the other Show buttons. It isn't much, but maybe it will be of some help.I didn't write in the release note that I had tried to fix your problem, because I haven't.
(The user you refer to has reported it worked in 5.2b2-4:
https://www.snbforums.com/threads/kamoj-add-on-5-1-beta-testing-poll.62315/page-8#post-578177 )
I'm sorry but my knowledge is not good enough to solve your issue(s).
My code in the router does not get your checkbox settings from the GUI.
I still suspect it has to do with Netgear code does not like your password or other setting.
Still good to get your report!
This add-on will remain in beta state and hopefully @nsx or some other smart guy understand what is wrong!![]()
Hello,New beta available!
Changes in kamoj-addon beta version 5.2b2-2
- DNS Privacy/Ad-Blocking: Corrected automatic (cron) update to work again (@microchip )
first little feedback v5.2b2-5 : unable to show device list in OpenVpn bypass page : tried with chrome incognito and internet explorer.
Tried before setting up OpenVpn Client : is it the tip ?
Hi,Thank you for the report and trying different web browsers!!!
If you have very many devices or heavy router load the page might time out.
If so, try to check the box: Show Only Active Devices
Best luck to you!
PS
Currently it's only for the OpenVPN Client - not for the Wireguard client.
thanks for reply but unfortunately still no device in list with or without checkbox "Show only Active Device" and waiting about 30min. Both on chrome incognito and internet explorer.
Do i have to downgrade to older version ? If yes, witch one ?
Thread starter | Title | Forum | Replies | Date |
M | Kamoj Kamoj Addon 5.5 Beta for Netgear R7800/R8900/R9000 with Voxel FW - Continuation | NETGEAR AC Routers and Adapters (Wi-Fi 5) | 41 |
Welcome To SNBForums
