Dear @jrbmw,@kamoj Tried again but still same error does not find the username or password.
If you run those command you need to uninstall and install the add-on again!Happy new year @kamoj and all on the board.
R7800 running voxel latest and updated to Kamoj 5.5.13.
Followed your guide
Still the same so I cleared nv ram and started from scratch
nvram show | awk -F= '/^kamoj/ {print $1}' | xargs -n1 nvram unset
nvram commit
reboot
Followed your guide .Added password ... Still same result password and username not saved
I will send you an e mail.
Sure, the config you sent to me is for Windows, and can not be run in a router.I downloaded it from their site yesterday.The configs work ok on individual devices.
Still it's made for Windows, and miss mandatory information like UDP or TCP.I put the first config I sent you in my linux box and it works ok
I took your configuration file and followed my instruction to you, and it was working; a password file was created!ok thamks @kamoj
I just tried putting a dozen configs on a usb stick openvpn-client
Read config put password in and same result.
All these configs worked in the past on the addon ...somethings changed.
[2022-01-01 16:09:40] [OPENVPN] Log erased by operator trigged addon
2022-01-01 16:10:16 15857.97 [OpenVPN] Client rc.common 27860: Information: start
2022-01-01 16:10:16 15857.99 [OpenVPN] Client rc.common 27860: ======== rc.common : /etc/rc.common =====================================================
2022-01-01 16:10:16 15858.07 [OpenVPN] Client rc.common 27860: Information: Check that OpenVPN Client is enabled
2022-01-01 16:10:16 15858.08 [OpenVPN] Client rc.common 27860: Information: Check that a configuration file is given and exist
2022-01-01 16:10:16 15858.09 [OpenVPN] Client rc.common 27860: Existing OpenVPN configuration selected in nvram: my_expressvpn_canada_-_toronto_udp.ovpn
2022-01-01 16:10:16 15858.10 [OpenVPN] Client rc.common 27860: check_password_file: . Get password file for: /etc/openvpn/config/client/my_expressvpn_canada_-_toronto_udp.ovpn
2022-01-01 16:10:16 15858.12 [OpenVPN] Client rc.common 27860: Information: Password file according to my_expressvpn_canada_-_toronto_udp.ovpn:
2022-01-01 16:10:16 15858.13 [OpenVPN] Client rc.common 27860: my_expressvpn_canada_-_toronto_udp.ovpn: Password file not given after auth-user-pass directive. Try to find/create one...
2022-01-01 16:10:16 15858.14 [OpenVPN] Client rc.common 27860: Information: find_password_file
2022-01-01 16:10:16 15858.16 [OpenVPN] Client rc.common 27860: Processing /etc/openvpn/config/client/my_expressvpn_canada_-_toronto_udp.ovpn ...
2022-01-01 16:10:16 15858.16 [OpenVPN] Client rc.common 27860: No password file found: /tmp/openvpn_client/idpw. Check pre-defined username/password
2022-01-01 16:10:16 15858.17 [OpenVPN] Client rc.common 27860: No password file found. No pre-defined username/password exist.
2022-01-01 16:10:16 15858.18 [OpenVPN] Client rc.common 27860: ERROR: No password file found and no default passwords exist. Exiting
2022-01-01 16:10:16 15858.19 [OpenVPN] Client rc.common 27860: Information: exit_it
Thank you for the new year giftChanges in kamoj-addon beta version 2021-12-31 5.5b13
- OpenVPN Client + Wireguard Client:
Automatically connect Wireguard or OpenVPN without having to manually
toggle OpenVPN Client on/off. (@KW., @jberry, @primitivo, @Panner)
Thread starter | Title | Forum | Replies | Date |
M | Kamoj Kamoj Addon 5.5 Beta for Netgear R7800/R8900/R9000 with Voxel FW - Continuation | NETGEAR AC Routers and Adapters (Wi-Fi 5) | 34 |
Welcome To SNBForums
