hi,
I have a smart switch on which I have several VLANs, including ACL rules. ASUS router RT-AC66U-B1 with the latest version of merlin FW is connected to VLAN10. In the router RT-AC66U-B1 on the LAN - Route tab I have set routing rules for individual VLANs. In the switch I have set the traffic that goes out of the VLAN to sell to the ASUS router. Everything works as it should. Internet works on VLANs where needed. The problem is the only one on the network map card - view list I see only VLAN10 where the ASUS router itself. Not participants on other VLANs. Is it somehow set up to see them?
When I look at the System Log - Connection tab, I see individual participants where they are connected, but there is no way to control them, such as disabling INTERNET for a while or using TIME SCHEDULING for them ...
Are there any attacks?
Thank you for any information that will solve my problem ..
Thank you.
Thank you.
