I am having similar problems to this thread (https://www.snbforums.com/threads/how-to-link-aggregation-lacp-on-rt-ac68u-w-r-p.20441/) with LACP my ASUS on merlin's newest 380.67_beta4 and my Synology DS1513+. At some point in the past, it was working but I, unfortunately, do not know when it stopped. It could have been months due to recent work travel. Hopefully, you guys can offer similar assistance if possible.
Asus and synology havent been able to help. I have posted on this forum and two others and had no luck. My previous inquiry within the referenced thread recieved no responses so I apologize in advance for the duplicate post. I wanted to try one last time before bothering Merlin.
MY SETUP
ASUS RT-AC5300 - Teaming is built in on ports LAN1 and LAN2
Firmware - Merlin 380.67 Beta 4
Synology DiskStation 1513+ - Also using ports LAN1 and LAN2
All cables are cat6 and tested working
I have gone through a slew of attempts to get this working again with no success. I have tried stock firmware, the custom teaming scripts for merlins firmware, tried remapping ports for different LAN jacks, etc. Before I came here, I have completely reset the router with latest ASUS firmware and then moved to Merlins latest 380.67.
ASUS SETTINGS/OUTPUT
ASUSWRT-Merlin RT-AC5300
admin@ASUS:/# ifconfig -a
agg Link encap:Ethernet HWaddr 00:00:00:00:00:00
inet6 addr: fe80::200:ff:fe00:0/128 Scope:Link
BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
bond0 Link encap:Ethernet HWaddr 34:97:F6:6F:A6:40
inet6 addr: fe80::3697:f6ff:fe6f:a640/64 Scope:Link
UP BROADCAST RUNNING MASTER MULTICAST MTU:1500 Metric:1
RX packets:31415 errors:0 dropped:0 overruns:0 frame:0
TX packets:66431 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:19741168 (18.8 MiB) TX bytes:11681270 (11.1 MiB)
br0 Link encap:Ethernet HWaddr 34:97:F6:6F:A6:40
inet addr:192.168.0.1 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: 2601:XXX:XXXX:XXXX::X/64 Scope:Global
UP BROADCAST RUNNING ALLMULTI MULTICAST MTU:1500 Metric:1
RX packets:203374 errors:0 dropped:0 overruns:0 frame:0
TX packets:199980 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:38622948 (36.8 MiB) TX bytes:134852394 (128.6 MiB)
dpsta Link encap:Ethernet HWaddr 00:00:00:00:00:00
eth0 Link encap:Ethernet HWaddr 34:97:F6:6F:A6:40
inet addr:XXX.XXX.XXX.XXX Bcast:XXX.XXX.XXX.XXX Mask:XXX.XXX.XXX.XXX
inet6 addr: XXXX:XXX:XXXX:XX:XXXX:XXXX:XXXX:XXXX/128 Scope:Global
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:1566454 errors:0 dropped:0 overruns:0 frame:0
TX packets:1587756 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1250603064 (1.1 GiB) TX bytes:1252601676 (1.1 GiB)
Interrupt:181 Base address:0x6000
eth1 Link encap:Ethernet HWaddr 34:97:F6:6F:A6:40
TX packets:6204 errors:0 dropped:2 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:1217638 (1.1 MiB)
eth2 Link encap:Ethernet HWaddr 34:97:F6:6F:A6:44
inet6 addr: fe80::3697:f6ff:fe6f:a644/64 Scope:Link
TX packets:6194 errors:0 dropped:2 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:1216876 (1.1 MiB)
eth3 Link encap:Ethernet HWaddr 34:97:F6:6F:A6:48
inet6 addr: fe80::3697:f6ff:fe6f:a648/64 Scope:Link
TX packets:6916 errors:0 dropped:1 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:1321869 (1.2 MiB)
fwd0 Link encap:Ethernet HWaddr 00:00:00:00:00:00
inet6 addr: fe80::200:ff:fe00:0/64 Scope:Link
UP BROADCAST RUNNING PROMISC ALLMULTI MULTICAST MTU:1500 Metric:1
RX packets:7880 errors:0 dropped:0 overruns:0 frame:0
Interrupt:179 Base address:0x4000
fwd1 Link encap:Ethernet HWaddr 00:00:00:00:00:00
RX packets:8500 errors:0 dropped:0 overruns:0 frame:0
TX packets:5005 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:1450002 (1.3 MiB)
Interrupt:180 Base address:0x5000
ifb0 Link encap:Ethernet HWaddr 9E:06:96:0D:9F:E1
inet6 addr: fe80::9c06:96ff:fe0d:9fe1/128 Scope:Link
BROADCAST NOARP MTU:1500 Metric:1
collisions:0 txqueuelen:32
ifb1 Link encap:Ethernet HWaddr 56:F3:C7:2B:96:48
inet6 addr: fe80::54f3:c7ff:fe2b:9648/128 Scope:Link
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MULTICAST MTU:16436 Metric:1
RX packets:10249 errors:0 dropped:0 overruns:0 frame:0
TX packets:10249 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:2269771 (2.1 MiB) TX bytes:2269771 (2.1 MiB)
vlan1 Link encap:Ethernet HWaddr 34:97:F6:6F:A6:40
RX packets:585607 errors:0 dropped:0 overruns:0 frame:0
TX packets:237047 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:80514372 (76.7 MiB) TX bytes:155531971 (148.3 MiB)
vlan2 Link encap:Ethernet HWaddr 34:97:F6:6F:A6:40
inet6 addr: fe80::3697:f6ff:fe6f:a640/128 Scope:Link
vlan3 Link encap:Ethernet HWaddr 34:97:F6:6F:A6:40
UP BROADCAST RUNNING SLAVE MULTICAST MTU:1500 Metric:1
RX packets:7940 errors:0 dropped:0 overruns:0 frame:0
TX packets:8923 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:3697423 (3.5 MiB) TX bytes:1584075 (1.5 MiB)
vlan4 Link encap:Ethernet HWaddr 34:97:F6:6F:A6:40
RX packets:23475 errors:0 dropped:0 overruns:0 frame:0
TX packets:57508 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:16043745 (15.2 MiB) TX bytes:10097195 (9.6 MiB)
MY SETUP
