Since I replaced the antennas on my RT-AC66R with some larger antennas, I wonder if the old antennas would work on the WRT1900AC? They're a little larger than the stock antennas, but I'm not sure if this is something that's product specific.
For this device - I would say no...
FWIW - it does support lazy beamforming for 802.11n for 2.4Ghz as well as 5Ghz - so this is now becoming a more interesting item from an RF perspective - lazy beamforming is a plus for all 802.11n clients...
sfx
What is "lazy beamforming"?For this device - I would say no...
Have you seen beamforming provide a significant performance improvement? If yes, how did you test?
One thing to look at if one has two of these units
I have two for as long as I need them. But not the time for further investigation of the WRT1900AC right now.Tim still does, hopefully, although he may've been required to send at least one back ASAP, not sure.
It's not the physical size of the antenna that counts.Since I replaced the antennas on my RT-AC66R with some larger antennas, I wonder if the old antennas would work on the WRT1900AC? They're a little larger than the stock antennas, but I'm not sure if this is something that's product specific.
If replacing antenna, it better be all 4 not just one. WRT is using 3 out of 4 antenna
diversity, it picks 3 antennas of 4 for best signal.
The Linksys WRT is a decent performer. However, as many others have mentioned, it is lacking in features when compared to others. Built in (free)DDNS service, OpenVPN/PPPTP server client, WOL, and lack of advanced statistics, logging, and access to more complex settings(to fine tune things) is why my Asus AC56U still remains my main router. The Linksys firmware I am not very fond of anyway.
Good stuff on the links - so allow me to pick on the specific nits you mention...
1) Free DDNS Service - ok, so what's the big deal? Install a client on your desktop from them, it's not like your dynamic IP changes every 15 seconds or minutes
2) OpenVPN Client/Server - this is a pox upon the world - OpenVPN is slow, thrashes the hell out of user space/kernel space as it's a UserLand application - L2TP is built into the IP stack and lives in kernel space - much faster - to OpenVPN's credit, it's good at hole-punching, but a proper L2TP config is as well, with less issues on IP overlap - note - I run an L2TP personal server and no issues noted....
3) WOL/WWOL - when was the last time you personally used this that depended specifically on the router? Maybe I've had it easy, but this hasn't been an issue...
4) Advanced Statistics/Tuning - come on - the one thing I would like is a public SNMP tree so that I can monitor usage - again, I'm not the average user, so most folks don't really care - as for tuning the WiFi (WiFi PHY, QoS, Traffic Shaping, etc), most folks really don't care, or have the knowledge to do so - touching them, well, it's site specific, and just because someone says it works better for them... well, probably not for others - my preference here is to not even expose them... between the Chipset OEM's and their board support packages and the OEM's, those engineers are not stupid - and they have an eye on performance.
5) Linksys Firmware on the WRT1900ac - it's functional, it's stable, and it works - and it's tweakable - the OpenWRT guys are kinda butt-hurt as the Marvell WiFi driver is a BLOB, ok... so be butt-hurt - in any event, Linksys has a tarball that, if you have a linux build environment, you can build and tweak on your own, just like rmerlin on the asus forums - see linky here...
WRT1900ac GPL Source - yes, you can download and build your own personal FW
This isn't an attack - just trying to clear the air here... most of your reviews and feedback are great.
sfx
It's not a blob any more, they were butt-hurt because it was a blob, but now they're happily playing with each successive release.
Still very messy though, & not terribly noob friendly for those that want to get involved, which is good at this stage of the game.
First off...these items I listed are included on routers nearly half the price.
1. Install a DDNS client? Who is "them"that you are referring to? The Asus DDNS service is buit-in to the router, there is no software to install. And, my IP does change frequently. I will not pay for a service that I can get for free, or use a free service where the host name expires every 30days(like no-ip). A top of the line router, in my opinion, no reason why it should not come with such DDNS service attached to it.
2. I have had the opposite experience with OpenVPN performance as you describe. I was using PPTP at first(from my Win Server 2012 box), but then switched to the built in OpenVPN when Asus implemented it. MUCH better performance. Plus, in TAP mode, allows me to remotely use my HDHomeRun Prime in Media Center. And OpenVPN only took me about a min to get working out of the box. Comparison of VPN severs I found here
3. I use WOL all the time. (I actually use WOL instead of pressing power buttons.) It is a huge time saver to tap on the smartphone app and remotely wake my systems, or access the router web UI and do it from there. The Linksys SmartWifi Firmware/App does not have WOL, even the routers Network map, sure, it lists all connected devices, why not have WOL.
4. I am not talking about average users here. "Average users" most likely aren't going to be inclined to purchase a top-of-the-line router, especially one that is priced higher than the rest. Linksys geared and is advertising this model for power or advanced users(whatever term you want to use) and for the OpenSource community, which generally is not the average consumer, but tweakers/modders. I am NOT an average consumer and thus, my reviews are not from that viewpoint and mindset.
My Asus(and other brands/models) have more advanced options. Thanks to this, I have greatly increased the performance of my router (from that of default/basic settings) to suit my needs.
5. Linksys firmware, has mixed opinions among users based on the threads and posts I have read. As with anything, there are folks with good and bad experiences...some hate it, some love it, some....indifferent, just as long as it performs and works well. I would say that it works, appears stable, and have basic to mid level functionality and features, but that's about it. (Also, most of their Smart apps you can download, are for iphone...and I am an android user.)
I have used OpenWRT and DD-WRT before awhile back...don't really like them personally. I love Toastman builds of TomatoUSB and Padavan firmware for the N56U. Merlins firmware is also very nice, but the stock Asus has more than what I need/want.
I am not a programer, and I have no interest in building my own firmware.
6. I wasn't aware "the air" needed clearing....![]()
http://bit.ly/1lJ89Ef
Simply put - IPSEC/L2TP is a better solution.
I set up VPN binds all the time in carrier space, and every one of them is a IPSEC/L2TP tunnel - I would never consider using OpenVPN for those tunnels, and I think my peers would do the same...
OpenVPN vs. L2TP - it's a holy war of sorts, and for this, I'll agree we're on different sides
FWIW - OpenVPN - it's handy for casual VPN's perhaps, I'll concede that, and like L2TP, it is secure...
That's awesome - and I've taken a different path - I don't use the NAS/Printer sharing functionality, VPN, etc... I have a dedicated server that sits on my desk and consumes about 10 watts in idle state - and it is much faster and more reliable than most consumer/SOHO access-point router appliances - it's called a MacMini with OSX Server.
sfx
Welcome To SNBForums
