ChaoscripT
The roaming will work even between different brand stand-alone APs, but without roaming assist technologies offered by network controllers. As I said the client decides where to connect and the decision to switch APs is based on specific criteria. All you can do on a stand-alone AP is set minimum RSSI level and the AP will attempt to disconnect the client below the threshold.
What I meant to, is there are access points that can be stand alone but talks with their friends, with built in controller like my Aruba.
But Unify/Ubiquity doesn't support it when you make it stand alone.
What are you trying to improve then? This is a very good signal. At least to where the PC is located.
It's not something that I want to improve as I don't know what the result if I were installed the AP like it should be (on ceiling or wall instead of on desktop)
