As the title says but here some background. I currently have a Netgear R7000 which has good range but not enough and the 2.4GHz band is slooow. The R7000 needed restarting every few days now, so it was flashed to FreshTomato Version 2024.1 and so far, so good. I preferred the single SSID of the stock firmware. Freshtomato firmware has to many options and reset to defaults doesn't seem to work completely. My current internet connection is a cable 500Mbps down/50Mbps up. I have a 50 TB TrueNAS with a 10 Gb connection connected to a 4 x 2.5Gbps + 2 x 10Gbps switch. The house is 2 stories concert and steal on a 50' x 100' lot of land. All 12 wireless devices are WIFI 6e.
Features I'd like to get:
Thanks in advance for you suggestion and help.
- Wide area coverage. FCC be dammed.
- OpenVPN Client for use with a VPN service
- OpenVPN server should I want to host a retro style but stay at home lan party
- Ability to use my Android phone as a modem if internet goes out.
- Some sort of Mesh networking so I can expand to get better coverage later on (preferably vender agnostic) with the ability to use either wired or wireless backhaul.
- Ability to use an 3rd party firmware (eg DDWRT) down the road.
- Wifi 7 if it's not much more.
