Malware Filter / bad host IPSET
do you see the the entry created by the script in your forward chain?
Chain FORWARD (policy DROP 0 packets, 0 bytes)
 pkts bytes target     prot opt in     out     source               destination
    0     0 REJECT     all  --  any    any     anywhere             anywhere             match-set malware-filter src,dst reject-with icmp-port-unreachable
Also... where are you pinging from?.... note the post here
http://www.snbforums.com/threads/malware-filter-bad-host-ipset.35423/page-2#post-298028
hi @swetoast Im using the malware script and thought it was working, but it looks like its not, I can ping a site thats in the malware filter
 ipset --list
Type: iphash
References: 1
Header: hashsize: 1024 probes: 8 resize: 50
Members:
One IP failed to respond
:/tmp/mnt/sda1/blockip# ping 98.215.45.16
PING 98.215.45.16 (98.215.45.16): 56 data bytes
But other did respond
 cat malware-filter.txt |grep 221.125.113.178
221.125.113.178
:/tmp/mnt/sda1/blockip# ping 221.125.113.178
PING 221.125.113.178 (221.125.113.178): 56 data bytes
64 bytes from 221.125.113.178: seq=0 ttl=47 time=316.413 ms
64 bytes from 221.125.113.178: seq=1 ttl=47 time=315.809 ms
And in the iptables -L -n -v comand there is no rejected packets
    0     0 REJECT     all  --  *      *       0.0.0.0/0            0.0.0.0/0           set malware-filter src,dst reject-with icmp-port-unreachab
Any ideas?
What do you get if you run this:
It should output all ip:s in that list.
ipset -L malware-filter
#!/bin/sh
# Original script by swetoast. Updates by Neurophile & Octopus.
path=/opt/var/cache/malware-filter                      # Set your path here
regexp=`echo "\b([0-9]{1,3}\.){3}[0-9]{1,3}\b"`         # Dont change this value
ipset -v | grep -i "v4" > /dev/null 2>&1
if [ $? -eq 0 ]; then
     ipsetv=4
     lsmod | grep "ipt_set" > /dev/null 2>&1 || \
     for module in ip_set ip_set_nethash ip_set_iphash ipt_set
     do
          insmod $module
     done
else
     ipsetv=6
     lsmod | grep "xt_set" > /dev/null 2>&1 || \
     for module in ip_set ip_set_hash_net ip_set_hash_ip xt_set
     do
          insmod $module
     done
fi
case $(uname -m) in
armv7l)
    MATCH_SET='--match-set'                             # Value for ARM Routers
mips)
    MATCH_SET='--set'                                   # Value for Mips Routers
    MATCH_SET='--match-set'                             # Value for Wildcard Routers
esac
get_list () {
        mkdir -p $path
        wget -q --show-progress -i $path/malware-filter.list -O $path/malware-list.pre
        cat $path/malware-list.pre | grep -oE "$regexp" | sort -u >$path/malware-filter.txt
 run_ipset () {
get_list
ipset --destroy malware-filter > /dev/null 2>&1         # Delete the filter so it doesnt clash with the update
if [ "$(ipset --swap malware-filter malware-filter 2>&1 | grep -E 'Unknown set|The set with the given name does not exist')" != "" ]; then
ipset -N malware-filter iphash
while read line; do ipset add malware-filter $line; done < $path/malware-filter.txt
iptables-save | grep malware-filter > /dev/null 2>&1 || \
iptables -I INPUT -m set $MATCH_SET malware-filter -j src,dst REJECT
fi }
run_ipset
exit $?
lets try this one last time and see if this works for all routers need to start versioning soon to keep up with demand for this script so i know what version everyone is running..
Looks like something is wrong because this is the result:
Type: iphash
References: 1
Members:
:/tmp/home/root#
 ipset --list
Type: iphash
References: 1
Members:
221.125.113.178
Any ideas?
The ipset is still empty, thanks for your help!
/tmp/home/root# ipset -L malware-filter
Type: iphash
References: 1
Members:
#!/bin/sh
     ipsetv=4
     do
          insmod $module
     done
else
     ipsetv=6
     do
          insmod $module
     done
fi
case $(uname -m) in
armv7l)
mips)
esac
get_list () {
        mkdir -p $path
 run_ipset () {
get_list
fi }
run_ipset
exit $?
Think i found the issue just gonna run some test to ensure that this time its right
Same issue
ipset --save > /mnt/sda1/blockip/malware-filter.txt
:/tmp/home/root# ipset -L malware-filter
Type: iphash
References: 1
Members:
Nothing in the ipset. And my malware-filter.txt had entries before the change in script but now it has this
 cat /mnt/sda1/blockip/malware-filter.txt
# Generated by ipset 4.5 on Fri Jan  6 07:32:29 2017
-N malware-filter iphash --hashsize 1024 --probes 8 --resize 50
COMMIT
# Completed on Fri Jan  6 07:32:29 2017
In INPUT chain you should always use: DROP
iptables -I INPUT -m set $MATCH_SET malware-filter -j src DROP
iptables -I FORWARD -m set $MATCH_SET malware-filter -j src,dst REJECT
im gonna need a day or two cause when i run each line separate it works flawlessly when i run it as a script it breaks so give me time
its specificly this line
for i in `cat $path/malware-filter.txt`; do ipset add malware-filter $i ; done that breaks it if you run it as a single line in separate script it loads the ips into the filter but inside the script it breaks
Type: hash:ip
Revision: 0
Header: family inet hashsize 16384 maxelem 65536
Size in memory: 395704
References: 1
Members:
24.182.214.6
185.35.62.86
193.106.81.206
211.38.71.81
37.53.95.16
187.161.7.88
85.97.186.11
88.248.204.116
180.178.132.26
31.42.188.10
61.91.37.18
83.104.230.199
93.116.147.15
185.46.248.129
31.129.111.16
37.29.47.183
91.244.25.238
201.166.237.149
46.233.15.123
111.23.15.130
213.231.18.241
50.186.230.154
13.54.22.118
178.174.209.174
107.150.44.58
Open to suggestions...
#!/bin/sh
     ipsetv=4
     do
          insmod $module
     done
else
     ipsetv=6
     do
          insmod $module
     done
fi
case $(uname -m) in
armv7l)
mips)
esac
get_list () {
        mkdir -p $path
run_ipset () {
get_list
    ipset -N malware-filter hash:ip family inet hashsize 2048 maxelem 65536
    for i in `cat $path/malware-filter.txt`; do ipset add malware-filter $i ; done   #THIS IS THE BROKEN LINE THAT MAKES THE SCRIPT NOT FUNCTION AS INTENDED
fi
iptables -I FORWARD -m set $MATCH_SET malware-filter src,dst -j REJECT
run_ipset
exit $?
Hi All,
I’m back. I had to step away for the afternoon. It appears there has been a lot of conversation in that time.
I can get ping replies from many sites in the malware-filter.txt file. I pinged those ip address from windows cmd prompt and got replies. I then pinged from the router SSH session with the same result. Here is more info that was requested:
admin@RT-AC88U-5248:/jffs/scripts# uname -m
armv7l
admin@RT-AC88U-5248:/jffs/scripts# ipset -L malware-filter
Type: hash:ip
Revision: 0
Header: family inet hashsize 1024 maxelem 65536
Size in memory: 8248
References: 3
Members:
Ouch, I have 3 entries in Chain FORWARD for malware filter. Probably from running the script 3 times?
Chain FORWARD (policy DROP)
target     prot opt source               destination
REJECT     all  --  anywhere             anywhere             match-set malware  -filter src,dst reject-with icmp-port-unreachable
TCPMSS     tcp  --  anywhere             anywhere             tcpflags: SYN,RST /SYN TCPMSS clamp to PMTU
ACCEPT     all  --  anywhere             anywhere
ACCEPT     all  --  anywhere             anywhere             state RELATED,EST                                                ABLISHED
DROP       all  --  anywhere             anywhere
DROP       all  --  anywhere             anywhere            state INVALID
SECURITY  all  --  anywhere            anywhere
ACCEPT     all  --  anywhere             anywhere             ctstate DNAT
admin@RT-AC88U-5248:/jffs/scripts# /usr/sbin/iptables -L FORWARD -v -n
    0    0 REJECT     all  --  *      *      0.0.0.0/0            0.0.0.0/0 match-set malware-filter src,dst reject-with icmp-port-unreachable
 9963  587K TCPMSS     tcp  --  *      *      0.0.0.0/0            0.0.0.0/0                                                            tcpflags: 0x06/0x02 TCPMSS clamp to PMTU
 749K  986M ACCEPT     all  --  tun11  *       0.0.0.0/0            0.0.0.0/0
 434K  41M ACCEPT     all  --  *      *      0.0.0.0/0            0.0.0.0/0 state RELATED,ESTABLISHED
    0    0 DROP       all  --  !br0   ppp0    0.0.0.0/0            0.0.0.0/0
    0    0 DROP       all  --  !br0   eth0    0.0.0.0/0            0.0.0.0/0
    0    0 DROP       all  --  eth0   *       0.0.0.0/0            0.0.0.0/0    state INVALID
    0    0 ACCEPT     all  --  br0    br0    0.0.0.0/0            0.0.0.0/0
    0    0 SECURITY   all  --  ppp0  *       0.0.0.0/0            0.0.0.0/0
    0    0 ACCEPT     all  --  *      *      0.0.0.0/0            0.0.0.0/0   ctstate DNAT
 6692  426K ACCEPT     all  --  br0    *      0.0.0.0/0            0.0.0.0/0
#!/bin/sh
     ipsetv=4
     do
          insmod $module
     done
else
     ipsetv=6
     do
          insmod $module
     done
fi
case $(uname -m) in
armv7l)
mips)
esac
get_list () {
        mkdir -p $path
run_ipset () {
get_list
fi
run_ipset
exit $?
If the malware-filter is referenced by an iptable it can't be destroyed right? so you would have to remove the rule first.......
x, destroy [ SETNAME ]
Destroy the specified set or all the sets if none is given.
If the set has got reference(s), nothing is done and no set destroyed.
yeah but its used by the kernel sooo we need to swap it, so it need a bigger re-write and today im busy hence my comment before about a few days..
so if anyone is up to the task and feels like rewriting so that the list gets loaded proper and then the rules get swaped on a update else all of this has to wait until i have more time on my hands.
Thanks for working on this @swetoast. No hurry here. I will check back periodically to see if there is an update. I greatly appreciate everyone's help.
Untested, remember adding an ipset might take time so dont rush it when testing.
#!/bin/sh
# Revision 1
     ipsetv=4
     do
          insmod $module
     done
else
     ipsetv=6
     do
          insmod $module
     done
fi
case $(uname -m) in
armv7l)
mips)
esac
get_list () {
        mkdir -p $path
run_ipset () {
get_list
ipset -L malware-filter >/dev/null 2>&1
if [ $? -ne 0 ]; then
fi
else
    ipset -N malware-update hash:ip family inet hashsize 2048 maxelem 65536
    for i in `cat $path/malware-filter.txt`; do ipset add malware-update $i ; done
    ipset swap malware-update malware-filter
    ipset destroy malware-update
fi
iptables -D FORWARD -m set $MATCH_SET malware-filter src,dst -j REJECT
run_ipset
exit $?
#!/bin/sh
# Revision 1
     ipsetv=4
     do
          insmod $module
     done
else
     ipsetv=6
     do
          insmod $module
     done
fi
case $(uname -m) in
armv7l)
mips)
esac
get_list () {
        mkdir -p $path
run_ipset () {
get_list
fi
else
fi
run_ipset
exit $?
Works ok for me...takes a while to build the set though.... maybe not a good idea to leave it in firewall start
