Malware Filter / bad host IPSET
@sobored04 why is that script introduced to this thread ?
updated the wiki with the latest revision with updated instructions.
Hi @swetoast for me it gives me the same error on the mips, thanks
/opt/var/cache/malware-filter/malware- 100%[=============================================================================>] 294.76K  84.4KB/s   in 3.5s
/opt/var/cache/malware-filter/malware- 100%[=============================================================================>]   7.34K  46.7KB/s   in 0.2s
Bad argument `family'
Try `ipset -H' or 'ipset --help' for more information.
ipset v4.5: Couldn't load settype `1.160.42.198':File not found
ipset v4.5: Couldn't load settype `1.160.43.75':File not found
I am looking at the updated instructions on the wiki and it seems /opt/ does not exist for me, I have a symbolic link to tmp/opt but in reality where it points to does not exist, is /opt/ a folder I should manually create or should I just point the script to a different location?
Check on how to install entware or just replace the path with a path of your choosing.. it doesnt have to be /opt it could be whateever you want.
Could be the same issue as in this thread here ... maxelem not supported
http://www.snbforums.com/threads/iphash-maxelem-not-supported-in-ipset-v4-5.35076/
please stick to the topic this thread is about the malware script if you want to discuss other scripts start a separate thread, dont threadjack !
im gonna add it as soon as more people test it and confirm that is working for em with a new description telling users not to add it to firewall-start unless they wanna wait 5 min when they reboot it better to have it as a service with cru in services-start
add the script to /opt/bin/malware-block
then type this
nano /jffs/scripts/services-start
and append
cru a malware-filter ""0 */12 * * */opt/bin/malware-block"
save it
I just ran the cru command as posted above but got an error about unexpected string. I removed the double ""0 with "0 and it worked. Correction below.
cru a malware-filter "0 */12 * * */opt/bin/malware-block"
Changes for mips please try @shooter40sw tnx for the guidance @tomsk
#!/bin/sh
# Original script by swetoast. Updates by Neurophile & Octopus.
# Revision 3
path=/opt/var/cache/malware-filter                               # Set your path here
regexp=`echo "\b([0-9]{1,3}\.){3}[0-9]{1,3}\b"`         # Dont change this value
ipset -v | grep -i "v4" > /dev/null 2>&1
if [ $? -eq 0 ]; then
     ipsetv=4
     lsmod | grep "ipt_set" > /dev/null 2>&1 || \
     for module in ip_set ip_set_nethash ip_set_iphash ipt_set
     do
          insmod $module
     done
else
     ipsetv=6
     lsmod | grep "xt_set" > /dev/null 2>&1 || \
     for module in ip_set ip_set_hash_net ip_set_hash_ip xt_set
     do
          insmod $module
     done
fi
case $(uname -m) in
armv7l)
    MATCH_SET='--match-set'                 # Value for ARM Routers
    HASH='hash:ip'
    SYNTAX='add'
    SWAPPED='swap'
    DESTROYED='destroy'
    OPTIONAL='family inet hashsize 2048 maxelem 65536'
mips)
    MATCH_SET='--set'                             # Value for Mips Routers
    HASH='iphash'
    SYNTAX='-q -A'
    SWAPPED='-W'
    DESTROYED='−X'
    MATCH_SET='--match-set'                 # Value for Wildcard Routers
    HASH='hash:ip'
    SYNTAX='add'
    SWAPPED='swap'
    DESTROYED='destroy'
esac
get_list () {
        mkdir -p $path
        wget -q --show-progress -i $path/malware-filter.list -O $path/malware-list.pre
        cat $path/malware-list.pre | grep -oE "$regexp" | sort -u >$path/malware-filter.txt
run_ipset () {
get_list
ipset -L malware-filter >/dev/null 2>&1
if [ $? -ne 0 ]; then
    if [ "$(ipset --swap malware-filter malware-filter 2>&1 | grep -E 'Unknown set|The set with the given name does not exist')" != "" ]; then
    ipset -N malware-filter $HASH $OPTIONAL
    for i in `cat $path/malware-filter.txt`; do ipset $SYNTAX malware-filter $i ; done
fi
else
    ipset -N malware-update $HASH $OPTIONAL
    for i in `cat $path/malware-filter.txt`; do ipset $SYNTAX malware-update $i ; done
    ipset $SWAPPED malware-update malware-filter
    ipset $DESTROYED malware-update
fi
iptables-save | grep malware-filter > /dev/null 2>&1 || \
iptables -D FORWARD -m set $MATCH_SET malware-filter src,dst -j REJECT
iptables -I FORWARD -m set $MATCH_SET malware-filter src,dst -j REJECT
run_ipset
exit $?
hi! @swetoast unfortunate it does not work
/opt/var/cache/malware-filter/malware-lis 100%[======================================================================================>] 293.48K   258KB/s   in 1.1s
/opt/var/cache/malware-filter/malware-lis 100%[======================================================================================>]   8.02K  --.-KB/s   in 0.1s
ipset v4.5: Couldn't load settype `1.161.165.231':File not found
#!/bin/sh
# Revision 3
     ipsetv=4
     do
          insmod $module
     done
else
     ipsetv=6
     do
          insmod $module
     done
fi
case $(uname -m) in
armv7l)
    HASH='hash:ip'
    SYNTAX='add'
    SWAPPED='swap'
    DESTROYED='destroy'
mips)
    HASH='iphash'
    SYNTAX='-N'
    SWAPPED='-W'
    DESTROYED='−X'
    HASH='hash:ip'
    SYNTAX='add'
    SWAPPED='swap'
    DESTROYED='destroy'
esac
get_list () {
        mkdir -p $path
run_ipset () {
get_list
fi
else
fi
run_ipset
exit $?
try again with the script above made changes.
seems that it failed from looking at it when it adds ip to the actual set
so i changed the syntax it should work now :)
I think its almost done, there is an error at the end but it does fill the ipset, it finishes in aprox 5 minutes 100% CPU, it says bad argument -X
/opt/var/cache/malware-filter/malware-list. 100%[=============================================================================================>] 296.25K   261KB/s   in 1.1s
/opt/var/cache/malware-filter/malware-list. 100%[=============================================================================================>]   8.02K  --.-KB/s   in 0.1s
Bad argument `−X'
are/var/cache/malware-filter# ipset -L
Type: iphash
References: 2
Header: hashsize: 132859 probes: 8 resize: 50
Members:
180.168.43.142
220.117.24.14
118.34.198.225
114.34.236.41
Chain FORWARD (policy DROP 0 packets, 0 bytes)
 pkts bytes target     prot opt in     out     source               destination
    0     0 REJECT     all  --  *      *       0.0.0.0/0            0.0.0.0/0           set malware-filter src,dst reject-with icmp-port-unreachable
ok so it has an issue with destroying old rules atleast its loaded the list that good news, yepp 5 min seems about right on an older model gonna put nice on it to make it less of a strain on the router
#!/bin/sh
# Revision 3
     ipsetv=4
     do
          insmod $module
     done
else
     ipsetv=6
     do
          insmod $module
     done
fi
case $(uname -m) in
armv7l)
    HASH='hash:ip'
    SYNTAX='add'
    SWAPPED='swap'
    DESTROYED='destroy'
mips)
    HASH='iphash'
    SYNTAX='-q -A'
    SWAPPED='-W'
    DESTROYED='--destroy'
    HASH='hash:ip'
    SYNTAX='add'
    SWAPPED='swap'
    DESTROYED='destroy'
esac
get_list () {
        mkdir -p $path
run_ipset () {
get_list
    for i in `cat $path/malware-filter.txt`; do nice -n 12 ipset $SYNTAX malware-filter $i ; done
fi
else
fi
run_ipset
exit $?
Something went wrong with this one
opt/var/cache/malware-filter/malware-list.pre    100%[============================================================================================================>] 296.25K   260KB/s   in 1.1s
/opt/var/cache/malware-filter/malware-list.pre    100%[============================================================================================================>]   8.02K  --.-KB/s   in 0.1s
ipset v4.5: Set already exists
#!/bin/sh
# Revision 4
     ipsetv=4
     do
          insmod $module
     done
else
     ipsetv=6
     do
          insmod $module
     done
fi
case $(uname -m) in
armv7l)
    HASH='hash:ip'
    SYNTAX='add'
    SWAPPED='swap'
    DESTROYED='destroy'
mips)
    HASH='iphash'
    SYNTAX='-q -A'
    SWAPPED='-W'
    HASH='hash:ip'
    SYNTAX='add'
    SWAPPED='swap'
    DESTROYED='destroy'
esac
get_list () {
        mkdir -p $path
run_ipset () {
get_list
fi
else
fi
run_ipset
exit $?
sry missed the syntax again had to many windows up try again :) sorry i updated the script with the correct syntax "SYNTAX='-q -A'" and i added nice to the process so it might take a bit longer to complete but less strain on the CPU
No worries ! thanks for the help and patience!
I rebooted the router and got an error while running again the script, it stayed again 100% CPU for 5 m regardless of the nice command
p/mnt/sda1/entware/var/cache/malware-filter# ./blockip.sh
insmod: can't insert '/lib/modules/2.6.22.19/kernel/net/ipv4/netfilter/ip_set.ko': File exists
/opt/var/cache/malware-filter/malware 100%[==========================================================================>] 159.99K  9.40KB/s   in 17s
/opt/var/cache/malware-filter/malware     [ <=>        ]   2.34K  --.-KB/s   in 0.005s
/opt/var/cache/malware-filter/malware     [  <=>        ]  10.51K  46.6KB/s   in 0.2s
/opt/var/cache/malware-filter/malware 100%[==========================================================================>]  17.00K  43.3KB/s   in 0.4s
/opt/var/cache/malware-filter/malware 100%[==========================================================================>] 296.25K   151KB/s   in 2.0s
/opt/var/cache/malware-filter/malware 100%[==========================================================================>]   8.02K  --.-KB/s   in 0.1s
iptables: No chain/target/match by that name
But it did create the ipset
/tmp/mnt/sda1/entware/var/cache/malware-filter# ipset -L
Type: iphash
References: 1
Header: hashsize: 199288 probes: 8 resize: 50
Members:
81.215.63.197
109.200.241.137
181.198.7.146
93.79.199.182
109.236.221.169
141.101.11.134
109.162.113.190
91.217.100.168
It did place the ipset in the iptables
And I tested if it was working, I pinged a random IP on the set before the script and responded and after and did not, so its working! Thanks a lot for your work and dedication, If you need any more testing let me know
    2   120 REJECT     all  --  *      *       0.0.0.0/0            0.0.0.0/0           set malware-filter src,dst reject-with icmp-port-unreachable
Awesome posted the version on the wiki and tnx for bearing with me and testing :) gets a little tricky when i dont have a mips router to use 2 different syntaxes
