Merlin & aiMesh
PavelBab
I have a problem with AiMesh on AC68U.
The router wifi is working normally when no any aiMash node is defined.
When I connect the Lyra trio (by Ethernet cable) into mesh system the router wifi is invisible. The aiMesh Node wifi is visible only. (tested the 2.4G wifi only by mobile phone)
The router wifi is visible again after the aiMesh node is deleted and the router restarted.
Is this operation normal?
I use the latest firmware by Merlin 384.14_2. The official firmware is not tested.
Regards
Regards
ahhhh the mysterious of the aiMesh
