These changes over time, but right now:
- It needs to be Broadcom-based
- It needs to be widely available (not just in two or three countries)
- It needs to have high-end hardware so I don't have to fight with lack of flash or RAM
- It needs to receive frequent enough GPLs so I won't have to regularly skip it due to the GPL being outdated
- I need to have one
- I need to have the time to try supporting it
- I need to have the motivation to try supporting it
Each new model requires its own dedicated support. That means every time I work on a new firmware release, I have to work on each separate model, and I need GPL releases from Asus for each individual model, and I need to merge each of them separately. So that means if I support 10 different routers, then I need to merge in the content of 10 different GPL releases, and these need to be close enough to one another to be compatible. The more models I support, the harder this is to accomplish, therefore I am VERY conservative regarding adding any new model. The RT-AX92U for instance didn't happen so far because it gets irregular GPL releases, it has limited market share, and I didn't feel like putting the 2-4 weeks of dedicated work just to add this specific model.
Right now in the short term, I have no plan to add any new model. The last two models I added were an absolute nightmare, and are still problematic to this day (as all three AX models receive GPL releases from Asus on three separate frequencies, one of which is currently out of sync with the two others. The sure thing is I won't even consider adding any new model until after the 386 code merge has been done for a sufficient number of models, which will at least help a little by unifying two separate code branches. That probably won't be done for a couple of months.
So, since there are too many variables involved, I no longer speculate about which model I want, nor which model I CAN support. It will happen if and when it happens. I can't know for sure until I have gone ahead and did all the necessary work to support it, to confirm whether it CAN be supported or not.
The amount of work involved for adding any new model is constantly increasing, which in turns make my motivation in doing so constantly decrease as a result. Just supporting what I do right now has pretty much reached the limit of what I am willing to invest in terms of time and efforts into this project.
