MarkhamSnappy
I've searched high and low, and I cannot find a tutorial to block ads on my shiny new router. Does ANYONE have an ARM based Merlin setup, with adblocking working yet?!?
The problem I've come across is, the ARM chipset doesn't support ENTWARE yet, only OPTWARE.
I've seen this tutorial, but it would'nt apply to the RT-AC68U, as it requires ENTWARE:
a) http://forums.smallnetbuilder.com/showthread.php?t=9449
And these tutorials, but they don't apply, as they are for Tomato:
b) http://www.shadowandy.net/tag/rt-ac68u
c) http://www.linksysinfo.org/index.php?threads/script-clean-lean-and-mean-adblocking.68464/
Anyone.. If you've managed to tweak an Entware adblocking setup (to work with Optware) on your router, or are simply a router genius and made your own, please respond and help us out here. I really like Merlin, but if I can't block ads in my house with all of my handheld devices (plus through a VPN tunnel), then Tomato is looking better every day.
ALSO... I used to run DD-WRT with Pixelserv, and am used to that and would really like to use it as well. (there is a port of Pixelserv for ARM out now)
