Hi there.....I hope someone can help as I have spent hours (days) trying to find an answer to this but to no avail. I currently have a HFC NBN connection which is where the existing ‘pay TV’ or cable network can be used to make the final part of the NBN network connection. In this circumstance an HFC line will be run from the nearest available fibre node, to your premises.
I would like to set up a MoCA Network using my existing coaxial cables. I do not have pay (or cable) TV but I do have an external roof antenna for free to air channels. The lead in cable from the antenna is split across the home into each room via a splitter. In the reading I have done to date, I believe I will need a PoE filter placed at the point-of-entry (PoE) of the cable coming into my home before the NBN NTD modem (DOCSIS 3.1) and another one at the lead in cable from the antenna before the splitter (to prevent broadcasting of MoCA signals). My question is, could the PoE filters instead be placed in every room I have a TV outlet if I am unable to easily access the roof to place it before the splitter? Has anyone had a similar set up? Thanks
