they may finally have fixed the under the hood values - I'll take a looklooks like I had a sw update on the virgin cable modem this morning:
21/10/2020 02:26:53 notice SW download Successful - Via NMS
21/10/2020 02:21:46 notice SW Download INIT - Via NMS
and it was rebooted:
Hardware version : 10
Software version : 9.1.1912.302
System up time : 0 days 9h:14m:25s
I now see upstream power ten times greater than before in the modmon chart:
the modem gui shows the previous/expected values:
@Jack Yaz - Some issue with the values being received via snmp, or scaling issue maybe?
Jon
please can you pm me a copy of 192.168.100.1/getRouterStatus?looks like I had a sw update on the virgin cable modem this morning:
Jon
modmon develop
@JonEngland @ColinTaylor
Please try the fix by running
option f in the cli menu. Also feel free to critique the updated WebUI! (this applies to everyone else who uses this script tooCode:modmon develop
NEW: modmon can be configured using the WebUI
NEW: Update modmon using the WebUI
NEW: Option to store database and configuration on USB instead of JFFS
NEW: Implement option to account for Upstream Power - 10x too high in latest Hub 3 firmware
IMPROVED: WebUI now uses a dropdown to select a time period for charts
IMPROVED: Reduced use of "lock files" to make script more responsive from the WebUI
CHANGED: WebUI tab name is now modmon and not Cable Modem Stats
I am interested in this on my Netgear modem as well. I was messing around a bit today and I was able to find the page to get the information unauthenticated. It is http://192.168.100.1/DocsisStatus.aspThis is the only thing i could find on my modem....doubt it will help at all though:
@Jack Yaz I've got a repeated issue with Modmon not mounting now. It's been every time on the last 4 reboots, including just now where I've updated firmware to 386.2 alpha 2.
can you PM me a copy of your syslog from a reboot where the tab doesn't appear please?Yes, same issue for me also on RT-AX86U running 386.1_2. The add on page fails to mount after a reboot. Not using unbound GUI either. Just spdmerlin, scmerlin and skynet.
Yes, will do. Can't do it just now as my household are all using the connection.can you PM me a copy of your syslog from a reboot where the tab doesn't appear please?
The Unbound GUI for a while now, for some reason, I've always had to manually install the GUI from AMTM after a reboot. However, I've rebooted it again without the GUI being installed (but unbound manager installed/ running in the background?) and I'll send the syslog over to you.do you use unbound gui? remove that for now and let me know if you still see issues please
Welcome To SNBForums
