modmon modmon - WebUI for monitoring Virgin Hub 3 cable modem stats
Would graphing Virgin Media Superhub 3 stats from Merlin be useful for you?
  • Yes
    Votes: 13 86.7%
  • No
    Votes: 2 13.3%
  • Total voters
    15
  • Poll closed .
Load the page with the network section of Chrome's dev console open, see how it is requesting the data
I use Safari and know how to open the console but I'm unsure what info you need?
A screenshot of all the loaded resources from network would be a good place to start please. On my Hub 3.0 I saw the stats page making a call to getRouterStatus which is what I hooked into
Hope this is the right thing...
Would you be willing to test load times on the develop branch please? I suspect it will take a similar amount of time, but loading is done chart by chart rather than all in 1 go
sure, what's the install command?
modmon develop
should do the trick!
a message flashed up, possibly an error but I didn't catch it and the usual modmon menu displayed (v1.0.0)
I tested time to show charts, results below:
average: 2s
raw: 17s​
If I retry the command I get this
# modmon develop
sed: can't move '/jffs/scripts/kMbJd9' to '/jffs/scripts/': Not a directory
modmon: No new version - latest is v1.0.0
average: 2s
raw: 17s​
# modmon develop
Weird, try swapping back with "stable" and then back to develop please
modmon stable
sed: can't move '/jffs/scripts/0aOH0a' to '/jffs/scripts/': Not a directory
it returns to prompt and doesn't load modmon
running just modmon works ok
modmon stable
Hm so sed is failing to edit the file. Check if modmon is stuck running in ps?
I don't see modmon running
# ps |grep modmon
24339 ac86u     5432 R    grep modmon
# modmon stable
sed: can't move '/jffs/scripts/sPYRP0' to '/jffs/scripts/': Not a directory
# ps |grep modmon
24439 ac86u     5432 S    grep modmon
It requires your router to be able to access the IP address of your cable modem
Note not all Status pages load from the same URL... here it is Index, SurfBoard SB6141
I have an Arris SB-6141 and when I go to install it tells me the modems not supported. Are there only particular Arris model that work with this?
@Jack Yaz I use this URL to get my signal levels without login into my modem... do you think it might work with your script?
In Argentina with ISP "Fibertel" it's an easy way to check the signal no matter which modem we are using.
http://www.dameunaip.com.ar/asp/nivelesPrima.asp
Using S.G.S9+ Duos w/ Tapatalk
Doubt this would work on a Netgear modem, correct?
