MyBookLive (NAS) and ASUS routers (RT-AC66U)
Yes, it's possible. Just make sure there is no any router's reboots on NFS heavy load.
Also, I'm using apcupsd on RT-N66U to shutdown WD My Book Live gracefully in case of power failure.
ryzhov_al,
I'm just curious, will the apcupsd shut down my Asus router gracefully if the battery is low? I'm thinking of buying an APC UPS (apcupsd) so my router with the attached My Book Essential and Live shutdown too. I understand that My Book Essential shuts down on its own if it detects that the router is turned off.
ryzhov_al,
Yes, it can be automated via script:
admin@RT-N66U:/tmp/home/root# cat /opt/etc/apcupsd/mbl_shutdown.sh
#!/bin/sh
# emssh_2.sh v.0.5
# ssh example for empty with job control, STDIN mode and session log
# Though, don't really know who wants to use empty for ssh :)
# Copyright (C) 2005, 2006 Mikhail E. Zakharov
ssh="/usr/bin/ssh -y"                           # (/full/path/to/)ssh
target="192.168.1.2"                     # target host
login="root"                            # username
password="welc0me"                      # password
cmd="$ssh $login@$target"
tmp="/tmp/empty.tmp"                    # tempfile to store results
echo "Starting empty"
empty -f -L $tmp $cmd
if [ $? = 0 ]; then
        echo "Sending Password"
        empty -v -w assword: "$password\n"
        sleep 1
        echo "Sending tests"
        empty -s << EOF
halt
exit
EOF
        echo "Check results:"
        sleep 1
        cat $tmp
        rm -f $tmp
        killall empty
else
        echo "Error: Can't start empty in daemon mode"
        return 1
fi
echo "Done"
It will log on to MBL's ssh console and run halt command. Don't forget to install the empty utility first:
opkg install empty
Wow! this is great :D thank you so much i'll try this one out.. just one more thing though, will the UPS shut my router down too?
