N14/N56/N65 QOS UP/DOWN + BFQ with Padavan's F/W builds
Alright so I tried the dhcpv6 stateless setting still no ipv6 :( address. I'm confused now.
Stateless for WAN and LAN. You only changed LAN. Also power cycle router AND modem and wait a while for the ipv6 to be obtained. If it does not work you can try "Both sources"
Did all the above you suggested moonman no succes here is the log:
Oct 4 09:07:31 DHCPv6 WAN Client: starting on wan (eth3) ...
Oct 4 09:07:31 dhcp6c[1950]: started
Oct 4 09:07:31 dhcp6c[1950]: sendto: Cannot assign requested address
Oct 4 09:07:31 dnsmasq[1953]: started, version 2.71 cachesize 1000
Oct 4 09:07:31 dnsmasq[1953]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP DHCPv6 no-scripts TFTP no-conntrack no-ipset no-auth no-DNSSEC
Oct 4 09:07:31 dnsmasq-dhcp[1953]: DHCP, IP range 192.168.1.2 -- 192.168.1.244, lease time 1d
Oct 4 09:07:31 dnsmasq-dhcp[1953]: DHCPv6, static leases only on ::, lease time 10m
Oct 4 09:07:31 dnsmasq-dhcp[1953]: DHCP, sockets bound exclusively to interface br0
Oct 4 09:07:31 dnsmasq[1953]: read /etc/hosts - 4 addresses
Oct 4 09:07:31 dnsmasq[1953]: read /etc/storage/dnsmasq/hosts - 0 addresses
Oct 4 09:07:31 dnsmasq[1953]: using nameserver 4.2.2.1#53
Oct 4 09:07:31 dnsmasq[1953]: using nameserver 4.2.2.2#53
Oct 4 09:07:31 dnsmasq[1953]: using nameserver 4.2.2.3#53
Oct 4 09:07:31 dnsmasq[1953]: using nameserver 2001:4860:4860::8888#53
Oct 4 09:07:31 dnsmasq[1953]: using nameserver 2001:4860:4860::8844#53
Oct 4 09:07:31 httpd[1955]: Server listening port 80 (HTTP).
Oct 4 09:07:32 dhcp6c[1950]: unexpected DHCP6 option , len 0
Oct 4 09:07:32 dhcp6c[1950]: unexpected DHCP6 option , len 301
Oct 4 09:07:32 dhcp6c[1950]: unexpected DHCP6 option , len 24736
Which router/build are you using? I'll make a build with gcc-4.4.7 just to make sure we are not running into a regression introduced by 4.9.1
Hello moonman :), right now I'm using RT-N56U_3.4.3.8-084-moonman-9 build.
Building with GCC-4.4.7. Will be available under k3.4 as 'test447'
Excellent :)
Edit: I just installed & tested RT-N56U_3.4.3.8-084-moonman-test447 and it works :D. Funny thing I used Stateful on both WAN & LAN settings.
Thanks for testing. I guess I will fall back to using 4.4.7 until I have time to investigate further or Padavan comes up with a solution.
EDIT: 084-moonman-9.1 will be compiled with GCC-4.4.7 (otherwise it is the same as 084-moonman-9) and all builds going forward will be compiled with GCC-4.4.7 until announced otherwise.
Awesome job :), just installed 084-moonman-9.1.
I also updated to moonman v10 for a customer and while it has worked great for the last 24 hours or so, it doesn't seem to display the Client List at all?
MuppetSoul, is your LAN Client list working? Router is an RT-N56U.
Client list works fine for me. All my LAN/Wi-Fi clients are listed properly. In fact, everything (2.4Ghz+5Ghz / QoS / VPN / DDNS / WINS / SMB / Port Forwarding / USB / WOL / HTTPS) is working fine on my end and I'm on the 24 hour mark. Not sure if its helpful but I manually assign IP addresses. And I tend to reset the router settings to factory default before every upgrade. Bad habit from Tomato days, I guess.
Here's the pic (I've hidden the Names and MAC addresses):
EDIT: I have RT-N56U as well and in the last 24 hours it saw about 38GB of internet traffic and a lot more network activity.
You may need to clear browser cache.
What does ASUS Info Discovery Service do ?
Thank you for your great work :)
