JT Strickland
OE, I just saw your decimal point. I didn't realize you could put decimals in there. Unless that is the decimal point after the 192.168.1(.) I bet that is what that is. And, I thought you had said that came from Merlin. I didn't mean to give undue credit. I thought I was quoting you on that. I must have misread, and I apologize.
Smokin, I will give that a shot, but I want to give the Aimesh the "old college try". It is a bit much with the two routers, but since I had them, I wanted to try and see how they would do. I got a helluva signal at the house, I guarantee you that. I had said earlier that I may put one of the pair of 68U's in the closet in case one of the others quit. I don't see how wireless could improve over an ethernet cable, either, but maybe it could complement it, I don't know. Sounds like you have already been through it and know what is best for your situation, which is similar to mine. If I try for myself and it don't work, I will remember and learn from it. Not only will I give your advice consideration, I will definitely give it a try. I almost started out that way after I got the RT-AC86U.
thanks again to everybody,
jts
jts
