Solved Need help Enforcing SafeSearch on duckduckgo.com
macster2075
Hi I have RT-68P on the latest Merlin firmware 384.19
I currently have a few scripts that forces SafeSearch in Google and Bing which work great...
For Google I am using this
echo address=/www.google.com/216.239.38.120 > /jffs/configs/dnsmasq.conf.add
For Bing...
echo address=/www.bing.com/204.79.197.220 > /jffs/configs/dnsmasq.conf.add
But....
I am stuck with DuckduckGo
I found the safe.duckduckgo.com IP address and I have tried the jffs below, but it doesn't work...
echo address=/www.duckduckgo.com/46.137.218.113 > /jffs/configs/dnsmasq.conf.add
also tried..
echo address=/duckduckgo.com/46.137.218.113 > /jffs/configs/dnsmasq.conf.add
Still nothing....
Any help on this?
Thanks.
take a look there
I think you would be able to do it by adding a cname record to your dnsmasq.add file like this:
cname=duckduckgo.com,safe.duckduckgo.com
Then I think you’d also need to put the IP address for safe.duckduckgo.com in your hosts.add file. But people have problem with it.
Tested this now and it works fine here with safe search for Google, Bing, Youtube and Duckduckgo
(via SSH)
Added: to /jffs/configs/dnsmasq.conf.add
cname=www.google.com,forcesafesearch.google.com
cname=youtube.com,restrict.youtube.com
cname=www.youtube.com,restrict.youtube.com
cname=m.youtube.com,restrict.youtube.com
cname=youtubei.googleapis.com,restrict.youtube.com
cname=youtube.googleapis.com,restrict.youtube.com
cname=youtube-nocookie.com,restrict.youtube.com
cname=www.youtube-nocookie.com,restrict.youtube.com
cname=bing.com,strict.bing.com
cname=www.bing.com,strict.bing.com
cname=www.duckduckgo.com,safe.duckduckgo.com
And created the file hosts.add in /jffs/configs (touch /jffs/configs/hosts.add)
Added: to /jffs/configs/hosts.add
::ffff:216.239.38.120 forcesafesearch.google.com restrict.youtube.com
::ffff:216.239.38.119 restrictmoderate.youtube.com
::ffff:204.79.197.220 strict.bing.com
::ffff:46.137.218.113 safe.duckduckgo.com
and then
service restart_dnsmasq
And check with for example cmd in windows
nslookup www.google.com (or change to bing.com, youtube.com, duckduckgo.com)
I only need for duckduckgo so the commands I need to add are...(sorry, I am pretty new at this)
1st - /jffs/configs/dnsmasq.conf.add
2nd - cname=duckduckgo.com,safe.duckduckgo.com
3rd -cname=www.duckduckgo.com,safe.duckduckgo.com
4th - hosts.add in /jffs/configs (touch /jffs/configs/hosts.add)
5th - /jffs/configs/hosts.add
then
is that correct?
Does it look something like this?
cname=duckduckgo.com,safe.duckduckgo.com >/jffs/configs/dnsmasq.conf.add - ENTER
cname=www.duckduckgo.com,safe.duckduckgo.com >/jffs/configs/dnsmasq.conf.add - ENTER
cname=duckduckgo.com,safe.duckduckgo.com > /jffs/configs (touch /jffs/configs/hosts.add) - ENTER
cname=www.duckduckgo.com,safe.duckduckgo.com > /jffs/configs (touch /jffs/configs/hosts.add) - ENTER
then - service restart_dnsmasq - ENTER?
These 2lines needs to be added to the file dnsmasq.conf.add located in /jffs/configs
These 2lines needs to be added in the file hosts.add located in /jffs/configs
(if it's not there it can be created with touch /jffs/configs/hosts.add)
Then
Then
So like this?
cname=duckduckgo.com,safe.duckduckgo.com > /jffs/configs/dnsmasq.conf.add - ENTER
cname=www.duckduckgo.com,safe.duckduckgo.com > /jffs/configs/dnsmasq.conf.add - ENTER
::ffff:46.137.218.113 safe.duckduckgo.com > /jffs/configs/hosts.add - ENTER
then
For Bing...
But....
also tried..
Still nothing....
Any help on this?
Thanks.
the biggest problem with duckduckgo is that they use infrequently ip address endpoints based on geolocation, the only way to keep duckduckgo safe search active is to periodically update the IP address of safe search for your area. Or use a resolver such as unbound where it can truly enforce with CNAME entries OR use Cloaking options with a resolver such as DNScrypt-Proxy 2. (CNAME cloaking). To properly do this with DNSMASQ, You need to first use NSlookup to determine the appropriate IP address for your duckduckgo safesearch before attempting to redirect regular duckduckgo to the corresponding addresses.
If any one is interested in taking the unbound approach, here is a mock script I devised for generating a .conf for unbound.
the first two commands wen through
but these.. I get not found..
I don't know how to add them as you said.. i've tried
::ffff:46.137.218.113 safe.duckduckgo.com > /jffs/configs (touch /jffs/configs/hosts.add)
but I get a message that says... -sh: can't create /touch: Read-only file system
-sh: syntax error: unexpected "("
Here is an example for DNSMASQ.
I made a script called /jffs/scripts/force-safe.sh
Then I added a line to /jffs/scripts/dnsmasq.postconf
to add the lines to dnsmasq.conf.
the attached files are good examples.
don't mind the .txt names the appropriate names should be force-safe.sh and dnsmasq.postconf
Thanks for that.. I only need for duckduckgo.com - i have google and bing covered.
I just need to know how to add these two lines
I keep getting a message that says... -sh: ::ffff:46.137.218.113: not found
I was told by Zastoff if it's not found I can add it using touch... but I don't know that touch is or how to use it.
What is the command line to "add" this using touch?
so the instructions are
- in ssh terminal do type
nano /jffs/scripts/force-safe.sh
copy and paste
the content of force-safe.txt .
ctrl x and enter to save
then the same with /jffs/scripts/dnsmasq.postconf
nano /jffs/scripts/dnsmasq.postconf
copy and paste
the content of the dnsmasq-postconf.txt .
then
chmod 755 /jffs/scripts/dnsmasq.postconf
as for zastoffs instructions you may need to PING or wait for him to clarify about his methods.
Touch command should be used within the SSH terminal to create the file if it does not exist, you type that in before trying to use echo.
echo "::ffff:46.137.218.113 safe.duckduckgo.com" > /jffs/configs/hosts.add
echo "46.137.218.113 safe.duckduckgo.com" >> /jffs/configs/hosts.add
ok.. did what you said... but nothing... safesearch in duckduckgo.com is disabled... do I need to reboot the router?
What I don't understand is.. why I can use
- to force safesearch on bing..
but I can't use
echo address=/www.duckduckgo.com/ 46.137.218.113 (or whatever the IP is) > /jffs/configs/dnsmasq.conf.add
- to force safesearch in Duckduckgo.com
