Need Help with entware+nginx+mysql+php+rewrite enabled
kanglinyao
First of all, I want to say thank you all for such a wonderful community and Merlin's Build.
I am using a AC66U with entware. The entware was installed in a harddrive attached to the usb port on my router.
I am trying to get this combination(see title) to work but as a newbie, I just cannot get this done successfully.
1. I successfully installed nginx and php. info.php can give php and server information.
2. I also installed mysql, but after the nginx and mysql restart. Wordpress install.php says that mysql module is not installed with php. (I did enabled the mysql in php.ini)
3. The rewrite is not working. (monstra CMS, a flat file cms is not working)
Could someone write a instruction on this topic.
Before this effort, I also tried lighttpd+mysql+php. Wordpress 4 runs smoothly, but I just cannot enable the rewrite. I read some articles and wanted give nginx a try. I really want to try databaseless cms on the router to reduce resource consumption.
