Need support in finding spaming DHCPDISCOVER device
TheUntouchable
Hi guys!
I just checked my logs after updating to a new version of scribe and saw a lot of entries like that (every 5 minutes):
Feb 6 21:45:57 RT-AC88U-DDF0 dnsmasq-dhcp[385]: DHCPDISCOVER(br0) 00:52:e0:9d:a5:1d
Feb 6 21:45:57 RT-AC88U-DDF0 dnsmasq-dhcp[385]: DHCPOFFER(br0) 192.168.1.80 00:52:e0:9d:a5:1d
Feb 6 21:45:58 RT-AC88U-DDF0 dnsmasq-dhcp[385]: DHCPDISCOVER(br0) 00:52:e0:9d:a5:1d
Feb 6 21:45:58 RT-AC88U-DDF0 dnsmasq-dhcp[385]: DHCPOFFER(br0) 192.168.1.80 00:52:e0:9d:a5:1d
I can't identify that mac address from my known devises and also couldn't find any vendor with that mac address. My computers ARP cache also doesn't know that mac.
Any hint how I can get rid of that device or know which device it is?
Thanks in advance.
If you dont find the culprit, you only have to put Hide DHCP / RA queries on YES, in Lan section-Dhcp server. Flooding will stop
That MAC is invalid, so either it's a virtual machine, or you have a device using a randomized MAC address for privacy purposes. I believe that's an iPhone feature, among others.
Thanks Merlin for the hints. The randomizing MAC address feature is also present on windows 10 machines, as I don't own an iPhone :D But none of my devices have activated that. There is no way to see if the request is coming from WLAN or LAN right?
Thanks for you reply, but I really want to hunt that device down as when its coming from WLAN it should have the key for it and thats not good :D
Does it pop up on the Wireless Log page?
I'm afraid not. It doesn't take the IP address from the dhcpoffer, so it doesn't have a real connection, only makes dhcpdiscovers every 5 minutes..
Simplest way is to manually reboot devices one at a time and see what pops up.
