NETGEAR WNDR3700 Reviewed
(new member here!)
Currently, I have one d-link dgl-4300 and it isn't enough to spread signal for all the house. Also I want to migrate to wireless-N (faster and more range)
First of all, thank you Small Net Builder for all your reviews, they are awesome and they help me a lot.
I'm thinking of buying this router plus RANGEMAX WIRELESS-N NOTEBOOK ADAPTER WN511B.
I would like to know if the difference will be really significant.
Also, does this router support ipv6?
Last question: how are your uptimes with this router?
Is there a way to combine or somehow bond the antennas that come with the WNDR3700 to get increased N bandwidth?
I originally got the WNDR3700 to upgrade another netgear N router, but I did some testing, exploring, etc.... end result... There's not much difference in performance between the WNDR3700 and the WNR854T. In fact, the WNR854T seemed to reach further. I decided to just put the WNR854T on one side of the house for general devices and the WNDR3700 on the other side of the house and, since the WNDR3700 no longer needs to support mixed clients, I figured it would be nice if I can max it out somehow. Distance isn't really an issue since it's basically serving two rooms right next to each other. I just want to tweak it to get the fastest wireless connection possible - any ideas on how to go about doing this? I'm getting 14 mega-bytes per second throughput right now with 300mbps, but can I get 600mbps somehow?
With the current firmware NTFS drive attached the USB port. It will freeze under certain conditions. (from Netgear's online help)
If there are many video and audio files in the USB drive and are over one hundred gigabyte capacity, the index file created by media server is too big for the system memory. This will be fix on the next FW release.
FWIW.
Bill
You also need a special receiver on the notebook you are using that is capable to do multi-band wifi.
By the way.. 15MBps is 120Mbps. What is your client adapter and its capabilities?
(new member here!)
AFAIK the WNDR3700 does not support ipv6 out of the box which is a shame because its D-Link cousin does support ipv6 and even has a dedicated page for it in its administration web application. So the hardware should support it.
I just got my WNDR3700 and it freezes after a couple of minutes when I connect a USB Terabyte NTFS HDD. If I don't do that it is rock solid when doing all kind of activities including bittorrent with DHT enabled.
Speedtest:
Pingtest:
I am more then happy with these results as it lets me use my full available bandwith of my cable connection that alot of other routers in the same or cheaper price range cannot.
Luminoso, in general, N routers don't extend range. They provide higher speed at a location where you can get a strong to medium strength signal with 11g products.
That being said, the WNDR3700's 2.4 GHz range is a bit better than other 11n routers that I have tested.
As I recall, it doesn't support IPv6.
I can't comment on reliability since I tested it only for a short time.
No. You would need a client that could receive on both the 2.4 and 5 GHz bands, which doesn't exist.
My client adapter is whatever comes in the latest Macbook Pro laptops. Would that work or would I need to get an add-on card?
Not really. You'd have to be able to bond them. I don't think there are any adapters that support this.
It doesn't have any VPN servers built in. And there are no enables/disables for PPTP, IPsec or L2TP. So, don't know.
it supports vpn passthrough (all 3 methods), as do all netgear routers. that means it will let outgoing client-connections through without the need to do any portforwardings.
it has no vpn capabilities on its own whatsoever.
Thanks for the info, beisser. I tried checking the specs and manual and didn't see any mention of VPN passthru.
netgear doesnt build any routers without that feature anymore. on prosafe devices you can disable it, on home-devices you usually cant.
Bingo - that was my experience with Netgear. They dont support and they do cut corners inside that product. So things do go wrong and when the do, good luck. If your time is worth anything, you'll be better off throwing the thing away and buying a new one.
That is not surprise and IMO it fits into the mentality of many electronics companies that churn out short term product and move on. So I'm in your camp - I had that experience with Netgear before and there are no spec on earth that would induce me to spend my money on their product ever again.
I am a little late to this party, but I wanted to bring some perspective to the "cut corner" remark.
Electronics companies like Netgear have to provide product at a competitive prices, otherwise you will buy someone else's product. Netgear, like the others who sell product in the general consumer space typically allocate 5-7% of their margin to support warranty claims, recalls, support desks, etc. Typical consumer class broadband routers costs you $60-$120. That is retail. So if Netgear wholesales your favorite router for $45, that is $2.25 per router that you have paid for a specific level of support.
Also, in an effort to keep costs down, they outsource the manufacturing and support. If Netgear expects to sell, say 50,000 of those routers they will pay some firm $112,500 to perform "support". That may include phone support, answers to web questions, etc. They pay regardless of how many are actually sold. The outsourced firm is highly motivated to keep their costs to a minimum.
Netgear is not alone in this approach to support of their products. Linksys, D-Link and the rest do the same thing.
If one expects a higher level of support with actual people who answer questions, follow up, record tickets of your issue, then you will see one of 2 things. A higher price that reflects the cost of providing that support, (typically 10-15% of wholesale) or most common, maintenance agreements.
This is where typically next tier brands become involved. SonicWall, Fortinet, and others. That is why they cost more even though in most uber-geeks eyes they perform the same function as that lowly Netgear from Best Buy.
So your perspective of what constitutes adequate support has a direct relationship to what you paid for the device. $2.25 of support gets you a 90-120 day warranty, a discussion board, downloadble firmware almost indefinitely, and a basic level of phone support.
So the next time you consider a new purchase, if you demand some level of support, you should research the product further, not just the lowest price on the shelf.
Well said, edwaleni. Good support costs money and so you get what you pay for with consumer products.
Is it possible to stream 1080p using wireless? I assume not but doesn't hurt to ask. (read in a user review 1080p youtube worked for him).
distance about 15 feet.
Are you asking about the WNDR3700?
Depends on a lot of things. But in general, most people don't find wireless good for trouble-free HD streaming, especially in areas with many networks.
