Just curious Melin which do you anticipate better; Asus 87U or the Netgear R8000? I just picked up the Netgear to "try out" and it's way faster on my lan and internet access than my N66U.
I have no plan on getting the R8000, so I'm not anticipating it at all. As for the AC87 I've had it for about a month now, so it's past the point of "anticipation" for me.
If you're asking me which of the two I would prefer to get if I had to chose, I'd say that wireless-wise, they're both just as good for my needs. My wifi usage is quite light (one laptop and a few mobile devices), anything that requires high throughput is connected over Ethernet. So, I have no need for dual 5 GHz radio (I almost never have more than one 5 GHz device connected), and MU-MIMO won't be of much use to me either for the same reason.
However software-wise, I prefer Asus's.
It looks like the devices are comparable but are you seeing a big Wi-Fi range advantage of the 87U over the N66U?
How did I guess you preferred Asus? ;-) You've had the 87U for a month now? Nice. I on the other hand with kids have several 5g devices running. Like you the important ones wired. I'm impressed with the Netgear but debating on returning for the Asus if I can find one before return time expires?? It looks like the devices are comparable but are you seeing a big Wi-Fi range advantage of the 87U over the N66U? The R8000 is slightly better on range but I was hoping for more. Might be my geography though.
I have to admit I lean toward Asus just because of your fantastic work buddy. ;-)
I may have to return and skip this one
Everytime I set some settings and the radios then reboot, 5ghz radio stops booting. Light never comes on, no broadcast and 5ghz settings page only shows channel 0 as an option. There's a bug somewhere.
The R8000 and the AC87 are not comparable at all
They work with completely different technologies and each router serves a different purpose.
The AC87 has only two radios and can use MU-MIMO (although no clients exist that support it, yet). But it has the highest possible AC link speed (1700 mbit, although, no clients support that yet either).
The R8000 (and the upcoming Asus AC3200, which is comparable to the R8000) uses three radios and Xstream (which is supported on all clients, old and new). However, the link speed on AC is "limited" to 1300 mbit.
The AC87 has probably better range than previous models, but all clients share the same radio in their repsective band (2.4 or 5 Ghz). What that means is if you have a mixture of different clients on 5 Ghz (or 2.4 Ghz), the router will slow down your fast 802.11ac clients to be able to also serve your slower 802.11n clients. Because they share the same radio.
The R8000 and the AC3200 on the other hand use XStream to intelligently distribute the clients to it's three different radios, based on client speed. For example, your fast 802.11ac clients will automatically connect to one 5 Ghz radio, your slower 802.11n clients will connect to the other 5 Ghz radio and your legacy 2.4 Ghz clients will connect to the third, 2.4 Ghz radio. This basically isolates the faster clients from the slower clients, allowing the faster clients to operate at full speed.
The AC87 cannot do this! It will always slow down to accomodate for the slower clients. So while on the box it says 1700 mbit for AC clients, you will never reach that speed as long as you have non-AC clients on the same network.
To sum it up:
If you have many different clients (mixture of a/g, n and ac), I would go for one of the Xstream based routers like the R8000 or Asus AC3200. They will give you much better overall performance.
If you have very few clients and only let's say n and ac clients, and if you need the 1700 mbit link speed to form a router-to-router wifi bridge, or if you need the higher range, I would go with the AC87.
Personally I will skip the AC87. By the time you ..........
Just wondering.... what's the difference between the R and U models (e.g. AC87R and AC87U or AC68U and AC68R)? I only see the U models on Asus' website.
I
For my setup, which router is better suited. ..... the Asus RT-AC87U/R or the Netgear R8000???
Both overkill! Lots of cheaper solutions. Your network is modest. As far as buying the latest and greatest, that will only be true for 2-6 months when the next models come out. Plus this is mostly an Asus forum, so guess which will be recommended the most?
Since you opened your router, kill the bug inside of it![]()
Are the shields really soldered? I find most are press-fit and can be carefully pried off. Watch out for itsy-bitsy components!They hide them under shields, I'd have to do a lot of unsoldering
So the couple of people on the forums here, who have been able to use this router for at least a couple days now. How is this router performing on the wireless side? Is it stable? As I have between 10-15 active wireless devices that connect between the 2.4, and 5GHz bands. I probably have around 7, or so that use the 5GHz band, and I use that band to stream HD stuff. So it's important to me to have stable wireless.
Because right now, I use the Netgear R7000, and its wireless is a nightmare. As I have only found Kong's DD WRT older build's with older drivers to give stable wireless so far. So I am thinking about switching back to Asus, with this new router. As I did like my N66U, and all the hard work Merlin put in. Before I made the switch to the R7000 6 months ago.
Welcome To SNBForums
