Hi there.
I'm trying my issue in this forum as it has been giving me a few grey hairs. My setup is as follows:
ASUS RT-N66 router -> switch -> clients
I have a VPN solution from Private Internet Access which i only use on one of the clients. I have tried running VPN directly on the router, and managed to have it running pretty well, but as i have a fast connection and really do only need the VPN on that single client i would like to use it on that single machine only.
The machine running vpn client also runs a few local services, like apache and tvheadend server which i would like to access from outside (using the wan ip) but when the vpn client is started no connections are coming in from the wan ip. It works perfectly locally, meaning i can use https://whatevermyhostnamecouldbe.com but from outside the wan nothing happens. Is what i am doing impossible, as the client running the vpn solution is not the routing device on the network?. The guides i have come across assumes that the client is running on the router and i am kind of lost here.
Best Regards
Best Regards
