May 4 05:01:59 syslog: wlceventd_proc_event(527): wl0.1: Auth C4:60:35:16:F1:2D, status: Successful (0), rssi:0
May 4 05:01:59 syslog: wlceventd_proc_event(556): wl0.1: Assoc C4:60:35:16:F1:2D, status: Successful (0), rssi:0
May 4 05:02:00 Diversion: Mounting Diversion WebUI page
May 4 05:02:01 kernel: ip_set: protocol 6
May 4 05:02:02 Diversion: Mounted Diversion WebUI as user1.asp in LAN/Diversion
May 4 05:02:02 syslog: wlceventd_proc_event(491): eth2: Deauth_ind 30:D1:6B:80:63:1D, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
May 4 05:02:02 syslog: wlceventd_proc_event(508): eth2: Disassoc 30:D1:6B:80:63:1D, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
May 4 05:02:03 connmon: Mounting WebUI tab for connmon
May 4 05:02:03 connmon: Mounted connmon WebUI page as user2.asp
May 4 05:02:03 Diversion: restarted Dnsmasq to apply settings
May 4 05:02:04 uiDivStats: dnsmasq has restarted, restarting taildns
May 4 05:02:04 kernel: br1: topology change detected, propagating
May 4 05:02:04 kernel: br1: port 2(eth0.501) entering forwarding state
May 4 05:02:04 custom_script: Running /jffs/scripts/service-event (args: start dnsmasq)
May 4 05:02:05 rc_service: udhcpc 1705:notify_rc stop_samba
May 4 05:02:05 rc_service: waitting "start_dnsmasq" via udhcpc ...
May 4 05:02:05 rc_service: skip the event: restart_nasapps.
May 4 05:02:05 scMerlin: NTP synced, scMerlin will now continue
May 4 05:02:06 custom_config: Appending content of /jffs/configs/hosts.add.
May 4 05:02:06 custom_script: Running /jffs/scripts/dnsmasq.postconf (args: /etc/dnsmasq.conf)
May 4 05:02:07 syslog: wlceventd_proc_event(527): eth2: Auth 30:D1:6B:80:63:1D, status: Successful (0), rssi:0
May 4 05:02:07 syslog: wlceventd_proc_event(556): eth2: Assoc 30:D1:6B:80:63:1D, status: Successful (0), rssi:0
May 4 05:02:08 Diversion: restarted Dnsmasq to apply settings
May 21 14:22:37 syslog: wlceventd_proc_event(508): wl0.1: Disassoc 10:52:1C:4F:79:55, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
May 21 14:22:38 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=xxx SRC=138.99.216.227 DST=xxx LEN=44 TOS=0x00 PREC=0x00 TTL=235 ID=56727 PROTO=TCP SPT=6
May 21 14:22:46 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=xxx SRC=185.156.73.109 DST=xxx LEN=40 TOS=0x00 PREC=0x00 TTL=237 ID=57740 PROTO=TCP SPT=5
May 21 14:23:19 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=xxx SRC=195.133.40.231 DST=xxx LEN=40 TOS=0x00 PREC=0x00 TTL=237 ID=54321 PROTO=TCP SPT=5
May 21 14:23:36 syslog: wlceventd_proc_event(527): wl0.1: Auth 10:52:1C:4F:79:55, status: Successful (0), rssi:0
May 21 14:23:36 syslog: wlceventd_proc_event(556): wl0.1: Assoc 10:52:1C:4F:79:55, status: Successful (0), rssi:0
May 21 14:28:36 syslog: wlceventd_proc_event(527): wl0.1: Auth 10:52:1C:4F:79:55, status: Successful (0), rssi:0
May 21 14:28:36 syslog: wlceventd_proc_event(556): wl0.1: Assoc 10:52:1C:4F:79:55, status: Successful (0), rssi:0
May 21 14:28:37 syslog: wlceventd_proc_event(508): wl0.1: Disassoc 10:52:1C:4F:79:55, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
May 21 14:28:53 syslog: wlceventd_proc_event(508): eth2: Disassoc F6:2B:2F:08:3B:F9, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
May 21 14:29:17 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=xxx SRC=185.191.34.91 DST=xxx LEN=40 TOS=0x00 PREC=0x00 TTL=240 ID=49658 PROTO=TCP SPT=52
May 21 14:29:35 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=xxx SRC=45.227.253.102 DST=xxx LEN=40 TOS=0x00 PREC=0x00 TTL=241 ID=35772 PROTO=TCP SPT=5
May 21 14:29:36 syslog: wlceventd_proc_event(527): wl0.1: Auth 10:52:1C:4F:79:55, status: Successful (0), rssi:0
May 21 14:29:36 syslog: wlceventd_proc_event(556): wl0.1: Assoc 10:52:1C:4F:79:55, status: Successful (0), rssi:0
May 21 14:29:39 syslog: wlceventd_proc_event(508): wl0.1: Disassoc 10:52:1C:4F:79:55, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
May 21 14:29:49 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=xxx SRC=194.26.29.169 DST=xxx LEN=40 TOS=0x00 PREC=0x00 TTL=234 ID=39638 PROTO=TCP SPT=52
May 21 14:30:03 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=xxx SRC=89.248.163.239 DST=xxx LEN=40 TOS=0x00 PREC=0x00 TTL=236 ID=54321 PROTO=TCP SPT=5
May 21 14:30:09 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=xxx SRC=91.240.118.245 DST=xxx LEN=40 TOS=0x00 PREC=0x00 TTL=239 ID=64749 PROTO=TCP SPT=4
I forgot that Skynet supports custom syslog locations. Try to run:they are different logs.
firewall settings syslog /jffs/syslog.log
firewall settings syslog1 /jffs/syslog.log-1
You could check the parameters of the running syslogd daemon in ps.I just caught wind of this, is this new syslog location universal or distinguishable via some method @dave14305 @RMerlin
/sbin/syslogd -m 0 -S -O /jffs/syslog.log -s 256 -l 7
/sbin/syslogd -m 0 -S -O /tmp/syslog.log -s 256 -l 7
No idea when that was changed. There is now a libshared function that returns the path to the syslog, and it gets used by rc when starting syslogd.I just caught wind of this, is this new syslog location universal or distinguishable via some method @dave14305 @RMerlin
It came with HND 5.04 withNo idea when that was changed. There is now a libshared function that returns the path to the syslog, and it gets used by rc when starting syslogd.
PSISTLOG=y in target.mak.PSISTLOG has been there for years, it's what made the log get copied to /jffs/ in the past.It came with HND 5.04 withPSISTLOG=yin target.mak.
It is only set to y in HND-94912_BASE, however. Defaults to n everywhere else, if I understand it correctly,PSISTLOG has been there for years, it's what made the log get copied to /jffs/ in the past.
I might have confused the two settings indeed. The PSISTLOG setting itself still isn't new, it has existed for over 5 years in the list of available config options (2017 is when the NG repo was created, so the setting is even older than that):It is only set to y in HND-94912_BASE, however. Defaults to n everywhere else, if I understand it correctly,
I believe RTCONFIG_JFFS2LOG controls the syslog copying to /jffs.
2e104e83cd1 (Eric Sauvageau 2017-08-27 01:27:50 -0400 1305) config RTCONFIG_PSISTLOG
2e104e83cd1 (Eric Sauvageau 2017-08-27 01:27:50 -0400 1306) bool "Persistent syslog"
2e104e83cd1 (Eric Sauvageau 2017-08-27 01:27:50 -0400 1307) default n
Not sure it will work, but you can try
And see if stats start to accumulate in Skynet.Code:ln -s /jffs/syslog.log /tmp/syslog.log ln -s /jffs/syslog.log-1 /tmp/syslog.log-1
We use essential cookies to make this site work, and optional cookies to enhance your experience.
