"No NSS support for mDNS detected" in the log
vrapp
Is this line in the log something to worry about?
May 5 00:05:09 avahi-daemon[251]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
No, it's just informative. Asuswrt does not provide NSS support.
I get this message in logs too, after I connect external SSD disk, Samsung pssd T7 touch, 1 TB - and it also shows on main screen that it is unmounted.
"fdisk -l" command shows that it is HPFS/NTFS system.
router: ASUS RT-AC86U, Firmware Version 384.19
did I hit some limitation of firmware ?
As previously stated the NSS message can be ignored.
Reformat the drive using NTFS. The Touch comes pre-formatted with exFAT which the router doesn't support.
