Nord Lynix on GT-AXE16000
cc666
Is there any way to get NordLynix on the GT-AXE16000? Nord VPN does not support wireguard config files.
Their answer to wireguard is NordLynix. Its pretty quict using the app on my laptop but I want
to install this on the Router side. I see no config files for this anywhere. Is it possible?
CC
No.
CC
If this is a router supported by Merlin get the latest alpha build then follow this website: https://github.com/sfiorini/NordVPN-Wireguard
I used an Ubuntu VM to generate my conf files my AX86U.
