Notifications (E-Mail)
I know it's a script, I have a gmail address and I downloaded certificate in /jffs/configs.
Please just post your entire script here or update wiki (without your email and pass, of course :))
My complete script (called "mail" and in my case located in /opt/home/root) is:
#!/bin/sh
sendmail -H"exec openssl s_client -quiet \
-CAfile /opt/home/root/cert/Equifax_Secure_Certificate_Authority.pem \
-connect smtp.gmail.com:25 -tls1 -starttls smtp" \
-f"[email protected]" \
-au"[email protected]" -ap"my_gmail_password" $1
I have downloaded the Equifax certificate into the file indicated (/opt/home/root/cert/Equifax_Secure_Certificate_Authority.pem) and I used the script like:
cat content.txt | /opt/home/root/mail [email protected]
From your text it looks as if you didn't feed sendmail any data, but the error message indicates something went wrong with the verification of the certificate.
I got the certificate from here (straight in .pem format). Just used wget to download it straight to the router.
http://www.geotrust.com/resources/root-certificates/index.html
Well, that was what I intended my first pasted line to help with. If you understand how the sendmail command works it should be easy to adapt the script. It should work with something like this.
#!/bin/sh
FROM="[email protected]"
AUTH="[email protected]"
PASS="gmail_passowrd"
FROMNAME="Your Router"
TO="[email protected]"
echo "Subject: WAN state notification" >/tmp/mail.txt
echo "From: \"$FROMNAME\"<$FROM>" >>/tmp/mail.txt
echo "Date: `date -R`" >>/tmp/mail.txt
echo "I just got connected to the Interwebz." >>/tmp/mail.txt
echo "My new IP is: `nvram get wan0_ipaddr`" >>/tmp/mail.txt
echo "" >>/tmp/mail.txt
echo "--- " >>/tmp/mail.txt
echo "Your friendly router." >>/tmp/mail.txt
echo "" **>>/tmp/mail.txt
cat /tmp/mail.txt | sendmail -H"exec openssl s_client -quiet \
-f"$FROM" \
-au"$AUTH" -ap"$PASS" $TO
rm /tmp/mail.txt
Note: You run this script on your own risk, I haven't tried it. If I made a typo that means it bricks your router, don't blame me.
My point was that you should never run a scripts that you don't know how it works. And if you understand how the script works I don't understand how you did not manage to put it together yourself.
i tried this script and got this error
connect: Connection timed out
connect:errno=145
sendmail: helper exited (1)
#!/bin/sh
PASS="xxxx2"
ntpclient -h pool.ntp.org -s &> /dev/null
sleep 5
echo "I just got connected to the internet." >>/tmp/mail.txt
echo "My WAN IP is: `nvram get wan0_ipaddr`" >>/tmp/mail.txt
echo "Uptime is: `uptime | cut -d ',' -f1 | sed 's/^.\{12\}//g'`" >>/tmp/mail.txt
echo "---- " >>/tmp/mail.txt
-CAfile /jffs/configs/Equifax_Secure_Certificate_Authority.pem \
-f"$FROM" \
rm /tmp/mail.txt
wait just figured it out. smtp.gmail.com:25 didnt work for me it kept timing out. using smtp.gmail.com:587 worked for mr
The reason might be that your ISP is blocking outgoing traffic on port 25 (spam prevention). In that case they should have a relay SMTP server set up for their clients (I know Swedish ISP Telia does this).
In that case you can use the simpler script against your ISPs SMTP server.
I don't know if my ISP even has a SMTP server... we got our fiber installed and it's working but I haven't received any information from the ISP... That's why I had to get the gmail SMTP server working.
this will send your syslogs to your gmail address
#!/bin/sh
PASS="x
FROMNAME="Router RT-N66R"
sleep 5
echo "Subject: Router RT-N66R" >/tmp/mail.txt
echo "Syslogs: `cat /tmp/syslog.log | less`" >>/tmp/mail.txt
-connect smtp.gmail.com:587 -tls1 -starttls smtp" \
-f"$FROM" \
rm /tmp/mail.txt
Another script to receive HTML email notifications when a torrent has finished downloading, read wiki
I added transmissionbt picture and made torrent name in bold.
Here is a screenshot
Connecting to Amazon SES and couple other tidbits
Connecting to Amazon SES:
Amazon SES requires TLS, so the previous examples for connecting to Gmail will work...with one minor change. Do not use the -crlf switch in the openssl command:
printf "Subject: $SUBJECT\nFrom: RT-N66U<[email protected]>\n\n$MESSAGE" | sendmail \
-H"exec openssl s_client -quiet -connect email-smtp.us-east-1.amazonaws.com:465" \
-au"$xxxxxxxxxxxxxxxxxxxx" \
-ap"$xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx" \
[email protected]
Also note: I didn't find it necessary to download the CA certs and reference them like was done in the previous Gmail examples. Openssl will complain that it can't find the cert issuer, but it will still proceed.
Other notes:
printf will preserve line feeds (unlike echo which escapes them), so you can redirect a string directly into sendmail instead of writing a file to the file system:
SUBJECT="My subject"
MESSAGE="My message line 1\nLine 2 of my message\nLine 3 of my message"
[email protected]
Also, remember that this distribution of sendmail has a verbose switch. If you are having trouble, activate it and it will probably show you why:
-v [email protected]
I have the wan-start script working and sending an gamil after the reboot of the router.
Is it possible to receive an email when een open-vpn or vpn connection is made?
A geek question :) ...
I use S/MIME to generally sign/encrypt each of my outgoing emails. So, I'm wondering if and how it is possible to enhance the mail script in terms of encrypting the notification email with the public key of my own recipient address before it is sent?
Sorry for this newbie question, but how exactly can I copy a script to this '/jffs/scripts' location? How can I access, e.g. view, this location in general. Do I need a separate tool/utility for it? (I am on a Win7 machine.)
TIA!
TIA!
Rather than TELNET/SSH into the RT-N66U and use the native 'vi' (or entware 'nano') editor, I enable SSH on the router, install WinSCP on Win7/8 then use WinSCP to open an 'SCP' session to the router then simply navigate in the right-pane to edit the script in /jffs/scripts;set permissions; and execute/test the scripts.
Regards.
