arthurlien
AiMesh is a name of the management system, repeater is a part of this system and managed by AiMesh.Stupid question maybe but what is the difference between repeater and aimesh?
我從使用 Tapatalk 的 ASUS_Z012DA 發送
Does it work via cable too?
I mean, when AP's are connected via ethernet cables to main router?
(main room)
cable modem is plugged into the wan port of my LEDE router
1 router lan port is plugged into the 24 port switch
wan port of AP node plugged into 24 port switch
100ft run from the main switch to the garage
Garage has master AP mesh. 100ft run is plugged into the lan port. Also a server is plugged into the lan port. Wan port of master AP is empty.
The only scenario i have not tried is, can i plug things into the lan ports of the nodes.
Thanks again, and I had to Google what a LEDE router was so I learnt something else along the wayAn OpenWRT fork of some kind. What hardware do you run it on and what are the big advantages for you?
StephenH
A bit off topic but why not.
Openwrt is about dead. It got so bad that last year they forked it, and all the devs moved over to lede project.
Lede has a very nice qos called CAKE. It is currently the best/newest out there and is even better than sqm. It completely eliminates buffer bloat(on stable connections), and is very fast on its reactions vs fq_codel (asus's best option via bandwidth limiter with the trick of putting in 192.168.1.1-199 for which pc to limit). I only have to give up 2% of my 120mbs connection (vs 5-10% with traditional qos) to get an A+ on dsl reports buffer bloat test.
I just started running the latest firmware on two rt-ac68u connected via a wired backhaul. I have Logitech Harmony hubs on the TV's, one is right near the node. If I use the app on my android phone to control it, the wifi from that node dies. When the wifi returns, any time I try to use it again the wireless dies again. When I have time I'll investigate further.
Since many of you have asked me, Here is the CFE that I used to get two TM-AC1900s working with the new AiMesh Firmware. I only had to write it to the master/router, not the node.
Brief instructions (you will have to re-configure the router after this process because you have to do a nvram erase/factory reset):
- Log in to router
- Go to Administration > System > Enable SSH > Yes > Apply
- Open Putty and WinSCP and connect them to 192.168.1.1 using a admin : admin or admin : password (or whatever you may have changed it to)
Tip: In WinSCP select SCP as file protocol, in Putty SSH- In putty type:
cat /dev/mtd0 > backup_cfe.bin- In WinSCP refresh the window on the right side and note that backup_cfe.bin is present
- Copy backup_cfe.bin to a local drive as a backup
- Download the cfe_from_ac68u.bin file from the link above
- Open the CFE with a hex editor or CFEEdit.
Modify the WAN Mac address and secret code as I have zeroed them out
Important: If you are going to put this CFE on more than one router on a common network, you should edit all the MAC addresses in the CFE so there are no duplicates on your local network.- Upload the edited CFE to router through WinSCP
- Upload mtd-write to router through WinSCP (Found HERE)
- In Putty type:
chmod u+x mtd-write- In Putty type:
./mtd-write cfe_from_ac68u.bin boot- In Putty type:
mtd-erase2 nvram- In Putty type:
reboot
The Guest Network is developing now for multiple APs.To those who have gotten the AIMesh running happily ...
Does the Guest Networks functionality work across all APs with AIMesh?
I assume it just gets set up on the Master (Will be in AP mode in my case) as per usual Wireless setup?
StephenH
That is VERY good newsThe Guest Network is developing now for multiple APs.
Around two months laterThat IS very good news, as I didn't even realise that it wasn't part of the implementation yet.
Any rough idea how long it will be until we see it?
And yes I realise software development is not an exact science and you may not wish to commit, but any information would be appreciated.
StephenH
I am running the aimesh firmware on a TM-AC1900 and for some reason after being online for about 10 minutes I lose the ability to access the internet. I know the internet is working because if I start a stream on Netflix the stream will continue but every PC has an issue. Any ideas?
The web Only available for aimesh router, not for Node.Does anyone else get this error when entering a node's IP address into the browser? If I'm not mistaken, I used to see another screen than the one I'm getting now.
The node does show up and seems to be active under the primary router's setup page.
I tried rebooting the parent and the node.
How many device are using this network?I'm getting the following error in the log and then I lose connectivity.
Nov 24 22:18:36 dnsmasq[889]: Maximum number of concurrent DNS queries reached (max: 150)
Nov 24 22:18:42 dnsmasq[889]: Maximum number of concurrent DNS queries reached (max: 150)
Welcome To SNBForums
