[Official] RT-AC88U Firmware version 3.0.0.4.380.858
if there is any asus reps in here :
i have poor eyesight, but i can read this without problems.
Try shift-reload to ensure that you don't have older CSS files in your browser cache.
Have u tried it yet? Does it significantly improve gaming speed on some international servers? How about heat problem? Is it as hot as the previous Asus router? And is it reliable?
Does this router have heat problem? And is it reliable?
Adaptive QOS seems to be broken, I can't choose Web Surfing as a default priority. Or at least it isn't staying highlighted after you choose it.
So it's still buggy. Does it overheat as well? How about reliability? I believe there is a bug like that, it is a major problem that Asus will eventually fix.
That page doesn't work by highlighting, it works by dragging the priorities in the desired order.
