OpenVPN keeps on turning itself off
Hmmm... I'll have to look into why it would have done that. Any chance you may have picked 2 VPN slots initially, and then changed it to 5 down the road?
I think the first thing to look at is to make sure that the /jffs/addons/vpnmon-r3.d/vr3timers.txt file looks correct. If you're missing any lines, just add using the example below:
VPNTIMER1=1714280868
VPNTIMER2=0
VPNTIMER3=0
VPNTIMER4=0
VPNTIMER5=0
After saving it, try stopping/starting vpn4/5 and see if the time comes back?
Thanks!
That worked however starting or stopping using the router's GUI to start and stop or using scMerlin didn't accomplish it the stop and restart had to be done in VPNMON and then have reenable monitoring the clients without timers.
