Advertising's purpose is solely to make you want to buy a product / service. Reality is always different.Yeah, it totally makes sense that they would be reluctant to support it. And it also makes sense that they might have warranty issues with 3rd party firmware.
But then don't advertise as a feature, right?
Warranty and support may be different. Warranty covers repair/replacement for broken / defective hardware. Support is helping customers with setup and operation.
And for warranty, how about damage because someone cranks the transmit power, or damages the board when accessing the serial header?
Buffalo is the only company that I know of that offers factory-blessed DD-WRT based routers. Doesn't look like it helped them gain much market share. But their warranty and support policy could be a model for others.
http://www.buffalo-technology.com/technology/partnered-software/dd-wrt/
I openly asked linksys why they didn't even include a vpn server and was told that was "extra". That blew my mind and yes that tells me their firmware is fully matured and will get no extra features.
I'll stick with asus
The WRT1900AC has dual partitions for the firmware. I think that if it fails to boot a certain number of times, the next boot will automatically be from the second partition. I haven't tested that myself, it was mentionned on the OpenWRT forums or mailing list.
I haven't tried pushing an image over serial, but the bootloader does seem to support a wide range of boot capabilities. Most likely it will also support TFTP, which is fairly common in such devices.
The serial header is on the right side of the pcboard, about two inches inside (if I remember correctly, I opened it a few nights ago and have since closed it). To reach it, you have to remove the four screws at the bottom (inside the feet - thankfully Belkin left holes in the rubber feet so you can easily remove the screws without having to remove the rubber pads). Then, pull the blue front plate forward (if I remember, it was clipped on either sides).
After that, you need to pull the black top cover. This one is your usual clam shell, with clips all around the sides.
Be CAREFUL there! Two of the antennas are on that top half of the shell, with the connectors at the front of the router. If you aren't sure, unplug the two center connections at the front first (make sure to note which goes where). You can plug them back after you have finished unclipping the top cover.
For the serial pinout, Victek posted this handy picture:
http://victek.is-a-geek.com/images/wrtac1900/serial_two.jpg
(that's right - you have to skip that third pin - possibly a CTS or RTS pin).
Serial port settings are 115200 8N1.
RMerlin,
I researched this more and hope I didn't harm my WRT1900AC serial port using RS232, 3 wire communication
Since I'm old school and have done a lot of work over the years with RS232 serial communications I assumed that was also the case with the WRT1900AC serial port.
The WRT1900 runs a new standard I had not heard of before TLL.
Differences between RS232 and TTL is:
1. Lower voltage 3.3 to 5 volts
2. The signal for a high bit is positive voltage (opposite RS232)
A TTL device is needed to connect to the WRT1900AC
RMerlin,
The use of TTL levels signalling isn't new, it's been used by embedded devices for years.
You do indeed need a TTL converter. Here's the one I use here (got it from eBay for a few dollars, includes the FTDI chip that interfaces USB to serial):
http://forums.smallnetbuilder.com/showpost.php?p=65838&postcount=7
Photos of a Topless RT-AC66U hooked with the adapter.
I should say new compared to RS232
Thanks for posting that link. There's some info in there that pertains to another discussion we're having in the other thread.
Seems like the DD-WRT guys are a bit hurt that Linksys didn't provide a full bootable image for them to hack into...
OpenWRT team - they're making a lot more progress...
https://forum.openwrt.org/viewtopic.php?id=50173&p=13
Welcome To SNBForums
