Optimal Antenna Positioning for AX88U Pro wall mounted?+
barkmarkin
Hey this is gong to be very authistic for me but I have my AX88U Pro wall mounted at the center most position of the house right behind TV, I live in a 2 bedroom one story apartment. and I always kept the antennas vertical. I mostly use 5GHZ so any advice would be appreciated. Maybe I can angle the side antennas like in the last pictuıre? Sorry for stupid question.it is mounted up high as possible without being eye sore how should I position the antennas to get the best signal at every corner.
or should I do it like this?
No need to post your question multiple times.
Sorry I wasn't sure where to post it, I guess I'll mount it a little higher then above the TV however it's behind the TV where most house is so
