Hello!
I recently faced the need to optimize my Wi-Fi network at home. I’m using two ASUS TUF AX4200 routers located in different rooms, about 15 meters apart, connected via Ethernet backhaul to create a stable Mesh network.
I downloaded the Wi-Fi Analyzer app to analyze channel congestion and found that, in the current auto mode, the router is using channel 3, which, according to the analysis, has very poor signal quality (one star).
This raised a few questions:
Thanks in advance!
- Should I switch the router from auto mode to manual channel configuration if Wi-Fi Analyzer shows that other channels are less congested?
- How do I properly select a channel to minimize interference, especially since I’m using two routers?
- Could Ethernet backhaul affect channel selection, or does it not matter?
- What other settings should I configure to improve signal quality and network stability?
Thanks in advance!
