Overclocking RT-AC56U
Was I reading the wrong line? On the RT-AC56U I thought I saw stock BogoMIPS was almost 1600?
My stats:
BogoMIPS : 1595.80 (800;533)
BogoMIPS : 2398.61 (1200;800)
At the attempt to set 1600;800, my router went to coma and so far I am not able to bring it back (swapped with my old trusty N56U temporarily)
Did you put 200,800 by accident? :)
lol or is the cpu protecting itself with insane throttling?
on another note a dual core 1.6 would be slightly less power then my sisters new asus s400ca we just got her. lol
lol you probably damaged your CPU
The RT-N66U. Now that you ask that, I see this thread was for the AC56U.
:P The Bogomips you were posting were in line with the N66/AC66, so I suspect that was your "problem" :)
My stats:
OBITUARY.
Rest in peace, o brave little black router. You died like hero exploring a new Everest of overclocking of routers. You will be missed.
My AC56 - just like Merlin warned about Fukusima - is not booting anymore. Only power LED comes on; attempts to get into recovery mode by holding reset button did not succeed.:(
Did you also try holding the WPS button while turning on the router?
See RMerlin's post on page 2 of this thread.
MILLION THANKS!!! Even though I could not find Merlin's post you are quoting, I did try - and magically it reset my bricked router!!!!
Hey, glad it worked!
Curious if there was a recovery tool for the RT-AC56U? Or is that available only for the RT-N16U?
There is, however the AC56U CFE is a bit more fragile, and can sometimes fail to configure the Ethernet interface. When that happens, the only way to recover is through a serial cable.
Thanks Merlin,
Could you please explain what does booting with WPS button do exactly and what is the correct procedure? I would to add that info to the very beginning of this thread (where I described recovery procedures)
