Padavan's Custom Firmware
Please, do not flash nightly builds until next week. Padavan says there are huge changes in repo, so it's hard to keep it consistent for a while.
Only if it's based on some Mediatek SoC.
It's not. The RT-AC56S is just a single core version of the RT-AC56U, based on a bcm4708.
Seems samsung dropped N56U from its updates. Been quite a while since new firmware/sources were published.
I do have some sort of question , using latest nightly 096. The laptop's wifi card was switched from a 150 mbps one to a 300 mbps one(2x2). I connect the laptop to the wifi , disconnect all other cable/wifi devices , do a speedtest and i get a max of 167 mbps. That would translate to about 20 mb/s. Real life test with a torrent or transfer never gets over 13-14 mb/s. Could that be because of the HDD ? I did swap the 5400 rpm one to a 7200 rpm one from a more expensive laptop and i hoped to get more. The older 150 mbps wifi card could get up to 12 mb/s , but the speedtest never over 80mbps.
Considering the upgrade from 80 mbps to 167 mbps i expected to get a bit more than 2 mb/s.
As a torrent client i'm using qBittorrent as utorrent went downhill in the past years.
Transfering from an external HDD with usb 3.0 gets up to 40-50 mb/s , which makes me believe it is not the HDD's problem with the low speed.
