pixelserv pixelserv - A Better One-pixel Webserver for Adblock
But don't we need to cross-compile to run it on our routers? (How?)
it says: but it fails...
2) Use the old Makefile-XC. E.g. to build for ASUSWRT,
make -f Makefile-XC arm
Here's what the current result is from the latest pixelserv build widely available. 10 years, 1024 bit, etc. despite the supplied certificate being changed.
Thinking about this example posted above, with that being from pixelserv, are the only things which NEED to be changed:
a) Key length 1024 -> 2048 bits
b) Days - 3650 --> 825
c) Are the other fields ok as is to keep pixelserv functional and in compliance with Apples new rules? IDK, I'm asking?
Without the proper testing which I have not done I can’t say definitively, but I assume the ExtendedKeyUsage extension will also need to be present. I hit a ton of snags trying to get a build environment going last night (Catalina breaks quite a bit of software).
Looking at that default cert again, it already has an EKU+SAN with a single DNS entry (*.bing.com). This is the part I do not understand. Is that the default cert generated b/c of the pixelserv code and is that fine with the rules or would each setup we have (say the router name) need to be pulled in as part of the cert? I just do not know.
Login to your router, then do Administration > System > Installed Server Certificate. What do you see? I think I recall there being instructions on using pixelserv to gen this cert which I did so it's another example. And yes it defaulted to 10 years.
Something akin to this?
Issued to : 192.168.301.5
SAN : 192.168.301.5 router.asus.com 1212-30105-AC86 1212-30105-AC86.mydomain.com
Issued by : 192.168.301.5
Expires on : 2028/5/5
There's no eku for tls server auth which is a requirement from Apple
I'm not an expert on any of this. Some of the stuff I've dealt with enough to manipulate, some of it I have a working understanding, and some of it I've heard about for the first time this week.
Whatever that is, it has nothing to do with pixelserv or the new tighter iOS/macOS rules
Is it as simple as this:
Not Critical
TLS WWW Server Authentication (OID.1.3.6.1.5.5.7.3.1)
TLS WWW Client Authentication (OID.1.3.6.1.5.5.7.3.2)
In other words, just that OID indicating what the certificate is used for? I took this from Cloudflare's certificate for snbforums.com
Not Critical
Not sure client is needed, but in my forked pixelserv I add the server auth eku
This is how/where I think that originated.. not 100% now --> https://github.com/kvic-z/pixelserv-tls/wiki/[ASUSWRT]-Use-Pixelserv-CA-to-issue-a-certificate-for-WebGUI
I had forgotten about his github page with lots of help.. so this is the one to externally generate a self-signed key and import it outside of pixelserv's nice neat way to stay outta the whole cert nightmare and quicksand!! --> https://github.com/kvic-z/pixelserv-tls/wiki/Create-and-Import-the-CA-Certificate
So if we can get the input strings correct + OpenSSL, we can generate the certs and import them?
But the rub still is the code actually checks for 1024.. length so that needs to be changed or just removed completely and any other checks along similar lines?
@Jack Yaz or anyone smarter and better with compiling than me: I would like to be prepared for the iOS 13 release.
I would need the usual ARM, Mipsel and AARCH releases in zip format, just like @kvic usually does.
A new version number would help too.
I could then modify the ps beta install script and code it into Diversion/amtm.
Any volunteers?
Looks like 13 could indeed be a bad number....
