D
Deleted member 22229
Guest
Is the iphone dropping connection and then reconnecting ? If thats the case assigning a static ip wont matter.
Double-check that you don't have two devices with the same name as I've seen some issues with that.How do I fix it? I am thinking the iphone goes to sleep and then awakes and reconnects.
Any ideas on a fix? Merlin any advice?
Whats crazy is my wifes iPhone does not do this. My iphone 6s plus does.
both connecting to the 5 ghz band.
CC
Do you realize that the issue is still there? You're just hiding the DHCP queries from the log...Here is the fix:
LAN-> DHCP SERVER tab then click YES to Hide DHCP/RA queries
CC
I also have same problem with some Apple devices connected to the 5GHz channel, curiously not with all of them but I'm assuming is a bug in the QTN drivers... so waiting for new drivers! Until there, I'm on the 2.4GHz...
Same issue here with the 3100. Alpha 3 - doesn't see the 5GHz network on multiple iphones/ipads but I can add the 5GHz network manually on them and it will connect. iphones/ipads see the 2.4GHz network fine.
And then Apple releases iOS 9.2, OS X El Capitan 10.11.2, watchOS 2, and Xcode 7.2 for which I need my internet connection...Hope to do that later this week.
87U on latest alpha3, chrome to webgui.
I'm finding the openvpn servers very twitchy. I have two instances (one tap, one tun) running. If I reboot, neither restarts. I have to go to each separately, where the tab is already showing "on", and click "apply" to get each to start.
I assume I can put something in services_start or wan_start to start them again on a reboot, but shouldn't they restart on reboot if they are set to "on"? And shouldn't the tabs show "off" if they are not set to start?
I haven't gone back to earlier versions to see if there is a change in behavior, or to other browsers. I prefer to access the router when away through the VPN, not by opening SSH on the WAN side, but maybe I need to?
I know Start With Wan is an option for the OpenVPN clients, but I don't see it for the servers.
Two iphones here and a ipad no issues connecting or seeing the 5 ghz band on 3100 with Merlin 57 alpha3. using channel 157 if that makes any difference.
8 320 DROP all -- any any anywhere anywhere state INVALID
Chain SECURITY (1 references)
pkts bytes target prot opt in out source destination
0 0 RETURN tcp -- any any anywhere anywhere tcpflags: FIN,SYN,RST,ACK/SYN limit: avg 1/sec burst 5
0 0 DROP tcp -- any any anywhere anywhere tcpflags: FIN,SYN,RST,ACK/SYN
0 0 RETURN tcp -- any any anywhere anywhere tcpflags: FIN,SYN,RST,ACK/RST limit: avg 1/sec burst 5
0 0 DROP tcp -- any any anywhere anywhere tcpflags: FIN,SYN,RST,ACK/RST
0 0 RETURN icmp -- any any anywhere anywhere icmp echo-request limit: avg 1/sec burst 5
0 0 DROP icmp -- any any anywhere anywhere icmp echo-request
0 0 RETURN all -- any any anywhere anywhere
| Thread starter | Title | Forum | Replies | Date |
[Preview] Work in Progress | Asuswrt-Merlin | 74 | |
| S | 102.7 Alpha Builds available | Asuswrt-Merlin | 150 | |
[ 3004_388.11 alpha Build(s) ] available build(s) | Asuswrt-Merlin | 36 | |
[ 3006.102.6 alpha Build(s) ] available build(s) | Asuswrt-Merlin | 206 | |
[ 3006.102.5 alpha Build(s) ] available build(s) | Asuswrt-Merlin | 111 |
We use essential cookies to make this site work, and optional cookies to enhance your experience.
