IAAI
Name of the website plzGetting good results though. Nothing fancy, no hieroglyphic entries in any fields.
Merlin where is the scheduled reboot function located at ?
Merlin how are you?
Even without the need of a factory reset, in my case i have all my configs noted here, is it good to make the reset as i won`t take long to make all my setup again?
Thanks!!!Doing so will certainly never hurt.
Probably it is a known bug, but I can't edit/delete/add entries under Qos/Bandwidth Limiter. I had to go with traditional QoS at the moment.
18d85bf Updated documentation
8c482f6 webui: Redundant, since there's now a Default dropper - Revert "webui: Re-added Empty category on Adaptive QoS page (removed by Asus a few months ago)"
579f735 miniupnpd: Revert structure version back to 1.1, as 2.0 breaks BITS, and probably other things as well
e1f9721 dropbear: Updated to 2015.70
4dd2128 miniupnpd: Only use rt_serial (380.57) and do not insert the rt_version (3.0.0.4), which we don't use
afc1adb webui: Fix port ordering on the Sysinfo page for the RT-AC3100
I'm uploading updated builds based on commit 18d85bf (give it a few minutes to complete).
Commit log since last build:
Code:18d85bf Updated documentation 8c482f6 webui: Redundant, since there's now a Default dropper - Revert "webui: Re-added Empty category on Adaptive QoS page (removed by Asus a few months ago)" 579f735 miniupnpd: Revert structure version back to 1.1, as 2.0 breaks BITS, and probably other things as well e1f9721 dropbear: Updated to 2015.70 4dd2128 miniupnpd: Only use rt_serial (380.57) and do not insert the rt_version (3.0.0.4), which we don't use afc1adb webui: Fix port ordering on the Sysinfo page for the RT-AC3100
This means that we should update? It will be alpha4? If not how do we know wich file to donwload?
Hi,I'm uploading updated builds based on commit 18d85bf (give it a few minutes to complete).
Code:579f735 miniupnpd: Revert structure version back to 1.1, as 2.0 breaks BITS, and probably other things as well 4dd2128 miniupnpd: Only use rt_serial (380.57) and do not insert the rt_version (3.0.0.4), which we don't use
As UPNP was updated and I get now massive log entries in my main router from all my devices like:
Nov 30 16:24:03 miniupnpd[1273]: Unknown udp packet received from 192.168.0.xxx:yyyyy
Anything I need to do here, or it's just a kind of re-connect of my devices (Dreambox video server, Sonos music streaming, etc.) to the changed UPNP version?
With kind regards
Joe![]()
Is this update only for those that use adaptive QOS or is it recommended for all ? Is a factory reset required if already using alpha 3 ? 6 days now since setting up my 3100 and it has been rock solid.
Update, this includes a UPNP fix that affects most Windows users. No need for a factory default reset.
There was no change related to QoS.
Nov 30 18:13:06 dnsmasq[877]: exiting on receipt of SIGTERM
Nov 30 18:13:06 custom config: Appending content of /jffs/configs/dnsmasq.conf.add.
Nov 30 18:13:06 dnsmasq[943]: started, version 2.75 cachesize 1500
Nov 30 18:13:06 dnsmasq[943]: DNSSEC validation enabled
Nov 30 18:13:06 dnsmasq[943]: warning: interface ppp1* does not currently exist
Nov 30 18:13:06 dnsmasq[943]: warning: ignoring resolv-file flag because no-resolv is set
Nov 30 18:13:06 dnsmasq[943]: asynchronous logging enabled, queue limit is 5 messages
Nov 30 18:13:06 dnsmasq-dhcp[943]: DHCP, IP range 192.168.200.2 -- 192.168.200.254, lease time 1d
Nov 30 18:13:06 dnsmasq[943]: using nameserver 127.0.0.1#65053
Nov 30 18:13:06 dnsmasq[943]: read /etc/hosts - 5 addresses
Nov 30 18:13:06 dnsmasq[943]: failed to load names from /tmp/opt/sda1/hosts/blacklist.txt: No such file or directory
Nov 30 18:13:06 dnsmasq[943]: failed to load names from /tmp/opt/sda1/hosts/hosts.blocked: No such file or directory
Since Merlin picked up the latest dropbearDoes this use the same version of dropbear that was causing the ssh tunnel issues in 378.56?
Does not resolve the log entries....Reboot your clients so they can refresh their mappings.
Welcome To SNBForums
