Lazy Larry
Thank you for your clarification. I am trying to verify if there is an issue with the firmware, my setup or the router, so I am using a second known to have working Guest network on stock firmware to change over to Merlin in a structured approach by first using 384.13 since this was reported/confirmed by psychosb that this version resolved similar issues reported.Uhm, 'verified to work with 834.13' is not a great predictor of 'it will work in 834.17'.
You're working with firmware from the future, or, the versions should be 384.13 and 384.17.
Seems I also can't get you to understand that all those SSID names are not 'proper' nor 'never before used' for your client devices if you used them (even for just testing) previously.
I hope this works out for you with the path you're following.![]()
Regarding your second point about the SSID names - I understand the points you raised about the SSID names not being 'proper', but this is the name of the Guest SSID I have previously used in 5 Asus routers located in two different countries and this is the name I want to use in the Asus router using the Merlin firmware. So either I find a working version or I will need to revert to the stock firmware.
