Problem with mounting during booting
gjf
Hi All.
RT-AC68U with latest Merlin firmware.
From some time I started expect problems with initial mounting of devices. I am using HDD for file storage and ext2 USB stick for Entware and config storage.
Everything was fine, but not now - please see logs: https://www.upload.ee/files/8738947/syslogs.zip.html
It really looks like the drive does not mount properly. How to fix it?
What is the specific problem you have? From the logs I can see that both sda1 and sdc1 have been mounted. Although sda1 looks like it has some corruption, probably because the swap file wasn't disabled prior to a reboot. So you need to reformat sda1 and recreate the swap file, and then make sure you issue a swapoff before any reboots.
Actually I already fixed corruptions and it allows me to use transmission again - corrupted settings file was the problem.
Anyway I still expect problems when connecting to ssh. It is quite interesting: when I try to connect using UnixAdmin app at my Android devices - it works like a charm. But kitty/putty/WinSCP PC clients stuck at login stage - they simply freeze after trying to connect to router. It is not always - but quite common case.
