Dennis Wood
A fix for RAID5 would be really good news indeed. Tim, with 5 of the Seagate 7200 RPM 1TB drives, our unit here is very quiet with the fan speed set to it's default temperature dependent low/med/high.
Regarding the "unregistered" posts above, I was thinking that the RAID5 issue must be code related as the RAID 0 speeds are nearly 10 times faster in our tests, as is the single drive performance. I'd be very appreciative if you could pmail (or email) contact information so we could get the beta firmware on this unit fired up
While you're at it, see if the Qnap wizards can provide NAS cache support for the Esata port
